3 members (Dennys28, 87GN, 1 invisible),
113
Mod | | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | ... I finally have the front of my cab finished. I had to replace both side full inner and outer cowls and both side floor boards/toeboards, straighten a twisted cab and fit two replacement doors of the correct year. Still lots to do, but this was definitely THE most complicated and time consuming thing I'll have to deal with. INSIDE OUTSIDE Now all I have to do is patch the dash, fix some rust on the windshield frame, replace the rear cab corners, replace the floor behind the seat riser, replace the bottom sheetmetal on the back of the cab between the corners, repair the rear cab braces, replace the gas tank brackets, replace the rear cab mounts, weld up a series of holes that were drilled in the roof for some unknown reason and then pull the cab, weld up everything that needs welding underneath and I'll be done... with the cab. Then all I have to do is.... Well, you get the picture  | | | | | Joined: Aug 2008 Posts: 26 Apprentice | | Apprentice Joined: Aug 2008 Posts: 26 | I have enjoyed looking at your pictures. Appreciate the detail and messages along with the pics. I will be starting on my cab in the spring 2009. And you and the stovebolt site have given me some very nice tips.
Please post pictures of the dash repair as I have some places below the key switch that will have to be addressed. And pictures of the windsheild frame repair as I to have some damage to repair there also.
Thanks, Tim in Richmond,Ky
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Woody ya did a very professional looking job...my hat is off to you Sir!....Congrats Tim | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Woody, I remember you telling someone " Guys like you are an inspiration"! You are in that category! Your attention to detail and the attitude to complete the correct way shows in everyway. Thanks for taking the time to photo and document. When your "finished" you look back in awe and have a big head and a smile ear to ear. As always good luck and have fun Dan
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Woodsman, you know they are building new complete cabs now don't you????
Seriously, I've been following your work for a while now. We started on these projects pretty close to the same time. You’re doing one bang up job and really trying for a decent restoration. Most guys would have made a street rod out of a cab that needed that much work. I think ya got the worst of it out of your system; the rest should be a piece of cake. I wish I were as far along as you, but you know, I'm much older and slower than you. I look back on the 5,000 man hours that I put into my Pitts biplane and then only flew it for a couple hundred hours, wish I'd have put the time in on an old Chevy instead. Rather, I wish I had that much time to spend on an old Chevy now. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Woody is DA MAN. He gives me hope. My panel is pitiful...cowls, floorboards,and rockers but I'm dedicated to making it work. Its guys like you Woody that keep going. I know you must have a sense of accomplishment and can "see" the final product. I do understand perfectly well what you meant by ......."and then all I have to do"  | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Good job man. I think we need to add to the "money pit" moniker for these old rides. I think we need to add something to the effect of "time bandits".
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Woody, I remember you telling someone " Guys like you are an inspiration"! That's very true. If it wasn't for this website I wouldn't know where to start and seeing some of the hulks these guys pull out of fields and turn into show pieces IS inspiring and raises the bar for everyone, myself included. I never set out to do a daily update on the work but I figured it would be a good way of keeping track of how much time I have invested and it is interesting to see the progress. Denny, Yea, I know they make new cabs but what fun is that? Alvin, I can assure you that your truck is no worse than mine. I just made myself a promise to do something on it every day and I have. When I first started this project everything that needed fixing upset me, I wanted it done NOW! But as time went on my attitude changed and I gradually began to enjoy the challenge. Now when I see something that needs to be fixed I just start formulating in my mind how I'm going to fix it. I'm having fun now. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Woody...I admire your tenacity! I would have given up long ago! I never realised just how good my cab was 'till I joined the 'bolt! I see the extent you 'guys' go to in breathing life back into tired iron! As Denny mentioned, you can buy new cabs,but at the end of the day YOU get the satisfaction of standing back and admiring your work. I tip my hat to you Sir! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Excellent work. Thanks for sharing your progress.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Woody, those are amazing pictures and I have to give you a big thanks for taking the time to show us the pics and detailed descriptions of the work you are doing. It is helpful to all of us to see details like that. Keep up the awesome work!
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Nov 2004 Posts: 2,404 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,404 | Looks Great!  John
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 88 | | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Nice work Woody and excellent documentation. I think you are at the "tipping point" where experience gained so far will begin to accelerate your progress.
Curt
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | very nice..good inspiration | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | hi woody philip here lookin good, as you remember we were doing engines at about the same time. i only have the front fenders left on my body work i had to take a break from that stuff. did you ever get your hands on a 250 hei i would be glad to fix one up for you, keep up the fine work. philip | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | Ain't it nice to sit back and look at what use to be rusted metal and see all that new steel. Thanks for your photos they have made my life a lot easier. Beautiful job.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | hi woody did you ever get your hands on a 250 hei i would be glad to fix one up for you. philip Hi Phillip, I put out some feelers for the HEI but as of yet nothing has come through... not like I'm putting any effort into finding one right now, I've got my hands full with other things. When I get to the point of putting the engine in I'll get serious about the HEI, but if one pops up I'll be in touch... Thanks for the offer! | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I think you are at the "tipping point" where experience gained so far will begin to accelerate your progress.Curt Very good point and I agree. Getting started is the hard part, but as you get into it it gets easier and "funner". | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ...Getting started is the hard part, but as you get into it it gets easier and "funner". I'll 2nd that e-motion  Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy ya hit the old nail square on the head that time Woody. I've not been able to get a head of steam up now for a few months. So all I've been doing is just puttsing around with a few small things and enjoying the driving experience. I'm hoping something will ignite my fire this winter and get me going again. I'm just simply out of room to do the major work that I need to do now and I score an F- when it comes to selling off the stuff that is blocking my progress, like two airplanes, 300+ old radios, 25,000 vacuum tubes and god knows what else. Here, just take a look at what a junk collector can accumulate in a life time; http://rides.webshots.com/photo/2574561000098611668okNnzH Now you can believe me when I say that I’m really ashamed that I let things get to this stage. I worked the last 25 years to get this workspace for the time when I retired and then just end up using it for a storage barn. I ask ya, wouldn’t this space look nice with a two-post lift, a 60” sand blast cabinet, a paint spray booth and a vintage Chevy 3604 sitting in the middle of the floor instead of all that junk! Then maybe I could get in gear and try and catch up with the ball of fire called Woody V… All I gotta do is get off me dufff and start selling this stuff off, cept I just simply don’t know how to go about that!! Denny Graham Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Geez, I thought I was bad. I'd seriously suggest an auction, but with the economy the way it is good luck getting rid of things at a good price.
Regardless, it ain't going anywhere until you set your mind to stop complaining about it and start doing something about it. Hate to sound harsh, but you know it's true.
Airplanes ain't no different than trucks... if you're wanting to get your money out of the thing forget it. | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | Nice work, Woody  That part of cab work is still in my future. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah I know, my "big old wife" has been singing the same tune to me for decades. I really shouldn't complain when some guys are working out of a car port and getting 10 times more than me accomplished. But if I did get rid of all that trash, what would I have to complain about???
DG
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | But if I did get rid of all that trash, what would I have to complain about??? Things like that .020" gap between the fender and cowl that you can't live with  | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Well Denny, AT LEAST KEEP the case of Bud Light!...lol Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ya mean there is a case of Bud Light hidden back in there, must have been there since I first tried it back in the Summer of '82. And I still can't drink the stufff, now a real Bud, that's a different story! Had to switch to that after they deep sixed Schlitz but I here it's making a come back in Milwaukee.
Denny , glug, glug, Graham Sandwich, IL
