5 members (Ridgeback, Otto Skorzeny, 39Master85, 1955 1 Series, Hanks custodian), 80 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
#465550 10/28/2008 2:18 AM
I hear a lot of guys with the 215/75 and 225/75 tires on a 16" rim. Anyone running 235/85 with 16" rim on a half-ton? Sam's sells them for vans and delivery trucks. They look tall and skinny kinda like the original bias ply tires and might get my rig going a little faster down the road.
Anton
They're a bit wide for the stock rims.
Bill Burmeister
dually rims are not but about 8 wide. I am going to put either 235/85s or 7x16 mudgrips on my 64
64 & 66 GMC long fleetside 4x4
Cartwright, OK
See if they sell a 215/85r16. That should work
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
215s won't be "tall and skinny"
Cartwright, OK
Compared to most of what's available in a 16", the 215/85/16 is "tall and skinny". Compare it to the current industry norm of the 245/75/16 and 265/75/16, you'll see what I mean.
Bill Burmeister
Yep, see what you mean...but 235/85 r16 dually tires in 6 plys are not 100 lbs a piece and have taller sidewalls (200 millimeters) versus the 215's 161.5 millimeter sidewall height, that should be about 3" of tire height.
Those 7" and 7.5" bias ply mudgrips look good also, but they are NOISY.
Cartwright, OK
Specifications for 215/85/16 and 235/85/16; 215s-section width-8.7" on 6" rim, overall diameter-30.5". 235s-section width-9.2" on 7" rim, overall diameter-31.8". These specs are for D (8 ply) and E (10 ply) load range tires, taken directly from the Michelin Data Book. I don't have weight specs, but neither size weighs more than perhaps 70#s max.
Bill Burmeister
215-85R16 is the radial equivalent of 600/650-16 in bias ply.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Anton,
I'm running 235/85-16s on my half ton, they are too wide for your stock rims.
I had the centers cut out of my stock rims and welded on to new outers that are 7 inches wide bead seat to bead seat, that's roughly 8 inches outside width.
Zero offset (neutral)
That is the widest rim you can run with your stock tie rod ends.
It is perfect, the tires fill out the wheel wells very nicely, the truck can run modern tubeless radials and the wider footprint adds much stability without sacrificing steering ease.
I am very satisfied with the way it came out.
