| | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 21 New Guy | | New Guy Joined: Jul 2005 Posts: 21 | I hear a lot of guys with the 215/75 and 225/75 tires on a 16" rim. Anyone running 235/85 with 16" rim on a half-ton? Sam's sells them for vans and delivery trucks. They look tall and skinny kinda like the original bias ply tires and might get my rig going a little faster down the road.
Anton | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They're a bit wide for the stock rims.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | dually rims are not but about 8 wide. I am going to put either 235/85s or 7x16 mudgrips on my 64
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | See if they sell a 215/85r16. That should work | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | 215s won't be "tall and skinny"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Compared to most of what's available in a 16", the 215/85/16 is "tall and skinny". Compare it to the current industry norm of the 245/75/16 and 265/75/16, you'll see what I mean.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Yep, see what you mean...but 235/85 r16 dually tires in 6 plys are not 100 lbs a piece and have taller sidewalls (200 millimeters) versus the 215's 161.5 millimeter sidewall height, that should be about 3" of tire height. Those 7" and 7.5" bias ply mudgrips look good also, but they are NOISY.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Specifications for 215/85/16 and 235/85/16; 215s-section width-8.7" on 6" rim, overall diameter-30.5". 235s-section width-9.2" on 7" rim, overall diameter-31.8". These specs are for D (8 ply) and E (10 ply) load range tires, taken directly from the Michelin Data Book. I don't have weight specs, but neither size weighs more than perhaps 70#s max.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | 215-85R16 is the radial equivalent of 600/650-16 in bias ply. | | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Anton, I'm running 235/85-16s on my half ton, they are too wide for your stock rims. I had the centers cut out of my stock rims and welded on to new outers that are 7 inches wide bead seat to bead seat, that's roughly 8 inches outside width. Zero offset (neutral) That is the widest rim you can run with your stock tie rod ends. It is perfect, the tires fill out the wheel wells very nicely, the truck can run modern tubeless radials and the wider footprint adds much stability without sacrificing steering ease. I am very satisfied with the way it came out.
