7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy),
136
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 8 New Guy | | New Guy Joined: Oct 2008 Posts: 8 | Is it possible to convert my straight L6 a.k.a 235ci engine into a fuel injection engine ? I've loooked into diffrent conversion system but have'nt found any kind of bolt on system . | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I think I would start out with some sort of TBI system. When I get my shop built this will be one of the first projects I will attempt. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I seem to recall reading something about altering a fuel injection system from a 4.3l V6, but that may be dust blowing around upstairs.  Try a search here and see what comes up. | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Don't the COE's use an updraft intake manifold and carburetor for body clearance? It would probably be possible to run a TBI unit upside down in place of a carburetor and adapt the necessary sensors to run it. Interesting idea! Jerry
| | | | | Joined: Feb 2008 Posts: 17 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 17 | In August a fellow Inliner and I put a GM TBI on my '53 Chevy Pickup with a 270 GMC engine. We had it running in about an hour. I'm preparing a presentation for my club meeting this Saturday. There is more to a permanent conversion than the demo that we did but it's not too hard. Junk yard parts and a Megasquirt.
"I wonder if God created man because he was disappointed in the monkey?" Mark Twain
| | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | a6row, what was the TBI you used original home? Mongo | | | | | Joined: Feb 2008 Posts: 17 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 17 | The TBI, ECM and wire harness came from an '89 full size GM van. You replace the ECM board with a Megasquirt board and a GM adapter board that plugs the GM harness to the MS. I think '88 to '92 will work. I've been parring down a '90 Suburban wire harness today getting ready for a presentation I'm doing at a club meeting Saturday. That takes some time and running fuel lines is some work. You have to have pressure safe lines and a return. Parts source is DIYAutoTune. http://www.diyautotune.com/
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I would personnaly search ebay for a holly 2DFI system. Used you can find a complete setup for under $200. This is only fuel side, your engine would still retain the existing spark side. Adjustments are simple, idle screw, power screw, richness screw.
Or you could find a GM TBI unit from a 4.3, get the complete setup and install it. It will run fine without having to go Megasquirt which can be difficult for those that havent soldered a MS kit together or programmed EFI on their own.
| | | | | Joined: Jul 2005 Posts: 77 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 77 | Search Clifford Performance. They have a TBI unit for the 235. I have not done this conversion so I can't get you very much details other than that I know that Cliffords delas a lot into the performance of the 235's.
John Kinser
| | | | | Joined: Feb 2008 Posts: 17 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 17 | Check these guys. I just came across it . http://www.affordable-fuel-injection.com/
