0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
Is it possible to convert my straight L6 a.k.a 235ci engine into a fuel injection engine ? I've loooked into diffrent conversion system but have'nt found any kind of bolt on system .
I think I would start out with some sort of TBI system. When I get my shop built this will be one of the first projects I will attempt.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
I seem to recall reading something about altering a fuel injection system from a 4.3l V6, but that may be dust blowing around upstairs. eek
Try a search here and see what comes up.
My 1953 Chevrolet
1947.1 Gallery
H Online: Content
Don't the COE's use an updraft intake manifold and carburetor for body clearance? It would probably be possible to run a TBI unit upside down in place of a carburetor and adapt the necessary sensors to run it. Interesting idea!
Here's a kit for the 250/292. Maybe they can offer one specific to a 235 if asked.
http://www.affordable-fuel-injectio...title=Chevy+Throttle+Body+Fuel+Injection
You Tube
In August a fellow Inliner and I put a GM TBI on my '53 Chevy Pickup with a 270 GMC engine. We had it running in about an hour. I'm preparing a presentation for my club meeting this Saturday. There is more to a permanent conversion than the demo that we did but it's not too hard. Junk yard parts and a Megasquirt.
"I wonder if God created man because he was disappointed in the monkey?" Mark Twain
"MONGO"
"MONGO"
a6row, what was the TBI you used original home?
Mongo
The TBI, ECM and wire harness came from an '89 full size GM van. You replace the ECM board with a Megasquirt board and a GM adapter board that plugs the GM harness to the MS. I think '88 to '92 will work. I've been parring down a '90 Suburban wire harness today getting ready for a presentation I'm doing at a club meeting Saturday. That takes some time and running fuel lines is some work. You have to have pressure safe lines and a return. Parts source is DIYAutoTune.
http://www.diyautotune.com/
I would personnaly search ebay for a holly 2DFI system. Used you can find a complete setup for under $200. This is only fuel side, your engine would still retain the existing spark side. Adjustments are simple, idle screw, power screw, richness screw.
Or you could find a GM TBI unit from a 4.3, get the complete setup and install it. It will run fine without having to go Megasquirt which can be difficult for those that havent soldered a MS kit together or programmed EFI on their own.
Search Clifford Performance. They have a TBI unit for the 235. I have not done this conversion so I can't get you very much details other than that I know that Cliffords delas a lot into the performance of the 235's.
John Kinser
Check these guys. I just came across it .
http://www.affordable-fuel-injection.com/
