1 members (Otto Skorzeny),
52
0
Mod | | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | I have a GMC 283EC. On the right side the rear leaf springs seem to be collapsed when I take a measurement. On previous attempts the grease would not go into the pin...even after cleaning it out. I'm not sure if the springs are collapsed or that the pin is badly worn...Help....I can get another set of springs...I just need to know what the best way of taking it off and putting the others on.
Matt
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | It is pretty straight forward just be sure and use new U-bolts and it is always best to replace the springs in sets. Inspect them pins and get new ones if needed and if you have trouble getting the pins out they may screw in to the spring eye with a machine type thread if the do there should be flats on them so they can be turned with a wrench. | | | | | Joined: May 2006 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 48 | is the spring collapsing or is it just the pin....
Matt
