0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#469412 11/09/2008 5:15 AM
I have a GMC 283EC. On the right side the rear leaf springs seem to be collapsed when I take a measurement. On previous attempts the grease would not go into the pin...even after cleaning it out.
I'm not sure if the springs are collapsed or that the pin is badly worn...Help....I can get another set of springs...I just need to know what the best way of taking it off and putting the others on.
Matt
\'47 GMC 1 1/2 ton, "Bertha"
1942 Chevy 2-Ton Truck, "Helga"
There is a fine line between "hobby" and "mental illness."
It is pretty straight forward just be sure and use new U-bolts and it is always best to replace the springs in sets. Inspect them pins and get new ones if needed and if you have trouble getting the pins out they may screw in to the spring eye with a machine type thread if the do there should be flats on them so they can be turned with a wrench.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
is the spring collapsing or is it just the pin....
Matt
