| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I replaced the rubber on my vent windows 4 years ago and I have never been able to get the windows installed right. They both slip out at the top where the rivet is supposed to hold the assembly in place. Does anyone have a diagram or some useful info? It's a 59 suburban. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | garretthes: I'm almost positive their is a good article in the tech tip section on this. It goes into some pretty good detail. I, myself, am about to take mine out before the doors go to the body man. Look around, i'm sure you'll find it. EDIT: Well I went and look it up for you. Try the link below. http://www.stovebolt.com/techtips/windows/vent%20rebuild/index.html
| | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | That's a good article but it doesn't show how the hardware goes on the pivot shaft once it's installed. There is a spring, nut and several washers. What about the rivet that sticks out the top? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Garrett ... bottom of page are pics of different points on the vent assy - the washers, especially the eccentric shaped one, are important - the spring tensions the glass frame so it stays in position up/down, the top pivot peg just floats in the hole there [clic a pic for larger, use "zoom" there to see full size] Bill | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Thanks! That's exactly what I needed. If only I hadn't just installed the custom door panels! | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I found several useful images on your site Red58. thanks for taking the time to post them. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you got it! I'm trusting they'll be there for reference long after I'm gone .... just hafta get Peg to li-nk it somewhere here  Bill | | |
