0 members (), 78 guests, and 12 robots.
Topics128,021
Posts1,055,355
Members48,420
#469098 11/08/2008 7:27 AM
I replaced the rubber on my vent windows 4 years ago and I have never been able to get the windows installed right. They both slip out at the top where the rivet is supposed to hold the assembly in place. Does anyone have a diagram or some useful info? It's a 59 suburban.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
garretthes: I'm almost positive their is a good article in the tech tip section on this. It goes into some pretty good detail. I, myself, am about to take mine out before the doors go to the body man.
Look around, i'm sure you'll find it.
EDIT: Well I went and look it up for you. Try the link below.
http://www.stovebolt.com/techtips/windows/vent%20rebuild/index.html
That's a good article but it doesn't show how the hardware goes on the pivot shaft once it's installed. There is a spring, nut and several washers. What about the rivet that sticks out the top?
More on Hotrodders
Garrett ... bottom of page are pics of different points on the vent assy - the washers, especially the eccentric shaped one, are important - the spring tensions the glass frame so it stays in position up/down, the top pivot peg just floats in the hole there [clic a pic for larger, use "zoom" there to see full size]
Thanks! That's exactly what I needed. If only I hadn't just installed the custom door panels!
More on Hotrodders
I found several useful images on your site Red58. thanks for taking the time to post them.
More on Hotrodders
you got it! I'm trusting they'll be there for reference long after I'm gone .... just hafta get Peg to li-nk it somewhere here grin
