3 members (baldeagle, Cosmo, CuzzFuzz), 77 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#467140 11/01/2008 10:50 PM
Apprentice
Apprentice
I have a 1962 Chevrolet truck 6 cylinder, 3 speed, on the column with OD on the dash.
I have been having an eratic speedometer. It holds steady for a while then goes back and forth any suggestions?
Tulsa
Tulsa #467144 11/01/2008 11:21 PM
Grease the cable
gazim #467149 11/02/2008 12:03 AM
Ex Hall Monitor
Ex Hall Monitor
Unless it's making noise it's probably not the cable. If lubing doesn't help you'll probably need to have it rebuilt.
Tiny #467151 11/02/2008 12:11 AM
Does the 'back and forth' correspond to when you're scratching something?
grin
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Tom R #467376 11/02/2008 11:10 PM
Apprentice
Apprentice
No I do not think I have any particular itch that would contribute to the eratic behavior of the speedometer. I will try the lubrication route first then maybe some foot powder!
Thanks!! grin
Tulsa #467574 11/03/2008 5:19 PM
My speedo does the same thing, please send me your left over foot powder.
Tulsa #467587 11/03/2008 6:33 PM
No Kidding....When mine acted like this, the advise was to push some vasoline into the back of the speedo where the cable goes, reattach cable. It works!
sfsutton #467592 11/03/2008 7:03 PM
You might also check the path of the speedo cable.....my needle will fluctuate if the cable housing is moved from side to side. Once I return it to it's favorite spot it's as steady as a rock.
As for grease on the cable....I think the recommended lube is a graphite based powder that won't stiffen up with cold weather.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Fla54Chevy3100 #468480 11/06/2008 12:46 PM
I also have a 62. Mine was doing the same thing, tried to lube it, no help, finally snapped the neddle off of it. had to replace the speedo. I figured it was worn out because it howled like a dog, a BIG dog when it was cold.
