2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | When putting everyting back together, do you use regular hardware or stainless or something else? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its a interesting topic, I've seen the suppliers that sell bolt kits or specific trucks, I've also seen specialty fastener companies selling correct hardware. I've used hardware store bolts and after a couple years not happy how they hold up. They usually are not plated the best. I think that the factory used different types of plating, zinc, phosphate and thats why even after many years of service the hardware still looks reasonable. I'd be interested in how to go about duplicating the factory process for hardware. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If you can afford it, I would go with Stainless. I don't know if originality is a big issue,but for looks and durability Stainless wins every time! Where possible I have used Stainless bolts/fasteners except where there are high tensile/shear factors. I have used grade 8 bolts in these situations, i.e Engine/suspension mounts etc. This was on the advice of my local hardware supplier. Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I agree with what Jock said. Stainless is not going to rust, but don't use it for critical fasteners, go with known quality grade 8.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | tclederman's link to Totally Stainless is good source for info. I ususally order from them directly by phone and not one of their many,many(including EBay) jobbers. That way you get quick advice for your project and can order a custom made set for anything on your truck. I recently had them put together a manifold stud kit rather then using their bolt kit.
Drew
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Amen to Totally Stainless. Be sure to treat them with an anti seize or you will regret it.
~Jim
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For those of you who are interested in getting as close to an original appearance as possible, Totally Stainless sells some black-anodized stainless-steel hardware. Their black recessed-head hex bolts look just like the original bolts used to attach the inner to outer fenders in the engine compartment (and the black recessed hex-head bolts/screws that attach the radiator shroud to the top of the grill and the top of the radiator).
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Is anti-seize still needed with the anodized stainless hardware?
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The price of stainless, its strength and its ability to bind on itself has kept me from going that route. Instead you can buy a whole heck of a lot of a durable clear coat with lots of money left over.
Jeff | | |
