0 members (),
147
Mod | | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46533 06/21/2005 9:39 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | What is the towing capacity of a 235? I have a 3 spd tranny (w/OD that can be locked out) and a 3.90 rear end. How did all this sawdust get under the hood? | | |
#46534 06/21/2005 9:51 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | up hill or down? Bill | | |
#46535 06/21/2005 9:55 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | How did all this sawdust get under the hood? | | |
#46536 06/21/2005 10:11 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | then very little! might pull a small aluminum boat on a light trailer, but the 235 only pulled med-heavy loads in the bigger trucks w/ 4.57 or 5.14 rear gears, and then pretty slowly - my 57 w/ that gearing hauls 3/4T or more in the bed, but not at highway speeds, and I avoid the ups Bill | | |
#46537 06/22/2005 3:48 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | The 235 barley hauls itself. Mine has trouble moving my 62, 3/4. If you hit a headwind and have a slight load, you will soon find yourself with no more pedal left. It's a sinking feeling. lol.....
delete my account and pictures
#46538 06/22/2005 4:22 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I have a 62 longbed with a 235 w/ a 4-speed and a 3.90 rear end. I pull a 1959 Glasspar G-3 (14') and trailer. The combo weighs just over 1000 lbs. It does just fine until I hit the hills. I can go 35 in 3rd gear on the real steep grades! I haven't towed the boat since I installed a set of fentons - there's one familiar hill I can't wait to test it on. By the way, What are you thinking of pulling? | | |
#46539 06/22/2005 4:41 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You'll find the limiting factor to be your brakes. Not many hills here in southern Kansas, but right now I have two tons of dirt in the back of my 52 3/4 ton, 4.10 gears and 31" tires. She will run 60 with that load on any hill around here, but with that much of a load I don't run over 40 cause she doesn't like to stop. The 1/2 ton has even less brakes.
Fred 52 3600 69 C-10
#46540 06/22/2005 6:07 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I have a GMC 270 in my '55 1st 1/2-ton, so I have another 35 cubes than your 235. The truck has an SM420 and 3.08 gears and modern 11 inch drums on the rear and 11 inch disks on the front.
I once pulled an 1800 pound trailer with two stripped car bodies sitting on it. I certainly felt the load both accelerating and stopping. It worked but wasn't fun.
I need to haul a 2000 pound load on the same trailer sometime in July and I'll be using a truck with a V-8 this time.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#46541 06/22/2005 6:32 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Looks like I've had more success with my 235. I've got a 3/4 ton GMC (1952) with SM420 and 4.56 rear end. I put a class 5 hitch on it and towed a U-haul flatbed trailer at a mile in altitude over dirt roads with a lot of washboard with a 2000 pound, engineless car on top. On the hills, I'd slow to 50, on the straights, I'd speed up to 60, so overall, I was able to average 55 in those rough conditions.
I don't think the 235 is capable of very serious towing either, but I was pleasantly surprised by how well it handled the U-haul car hauler.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#46542 06/22/2005 6:38 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Dad I'd bet much of the difference in our experiences is your 4.56 gears compared to my 3.08s. My motor isn't spinning as fast at 70 as yours does at 50.
Is it a Canadian GMC or a replacement motor? My '52 GMC came with a 228.
#46543 06/22/2005 6:54 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yeah, no doubt. I don't have much top speed, but the torque is decent for an I6. No, it's not Canadian as far as I know. I bought it up in Wyoming and drove it down to Colorado. It had a GMC motor, I don't remember the size, but it had a screwdriver stuck in the piston when the guy tried to get it rebuilt. The screwdriver destroyed the original motor, so he found this 235 to rebuild for it.
#46544 06/22/2005 7:26 AM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | I pulled a 2500# Datsun and 2500# of tools and car parts with my 48 Chevy 1/2T from San Diego to Seattle with the 235, SM420 and 4.10 gears with 235x70x15's. Top speed was 55-60. And the hills meant 3rd gear at 35mph (up and down hill, didn't trust the huck brakes with that much weight). Gas mileage was 11-12 mpg the whole trip, and she didn't drink a drop of oil, even through the Sacremento Valley in May when temps were around 90-95. Made the trip in 2 1/2 days, but my 48 has twin tanks (the 48 under bed and a 50 behind the seat), so gas stops were not too often, just a bit more pricey. :-) Hope this gives you a few ideas. I would get a SM-420 for any towing duties, as a friend had a 60 with 235 and 3 speed that he blew up 4 3spds just pulling a 2200# utility trailer around WA state and that was with a bone stock 235... Garry K
Garry K in Pac Nor West 1948 Chevy PU 235 SM420 4 spd 1932 **** B pu 1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#46545 06/22/2005 4:58 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I have a picture of my 48 3/4 ton with a tired 235, loaded with a ton of hay in back. I am geared low and I dont even have to shift down on corners from 4th. Hills are no problem either, just slow. I have pulled my 16 foot horse trailer as well and it did fine in its speed range. I would not get on a major road with or without a load with my low gearing. These engins have loads of torque for pulling, but lack the horsepower to pull at modern speeds. Ralph | | |
#46546 06/22/2005 6:35 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I want to dump this 235 and replace it with a small diesel. We had a good discussion about this not long ago.
#46547 06/22/2005 9:51 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | I have towed a 16' empty flatbed trailer 250 miles at 65 MPH most of the way with no problems. There were a few hills, but nothing significant. I need to buy fencing materials like 8" wood posts, 4" posts, t-posts, barbed wire rolls, etc., and the vehicle that I usually use for towing may not be available. Depending on how much I buy at a time, it could be a heavy load. However, I usually won't have to go but 10 miles with the load. How did all this sawdust get under the hood? | | |
#46548 06/22/2005 10:26 PM | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | Pardon my ignorance, but what is a SM420??
Kels
Half Ton Will Travel God bless America...One nation under God
#46549 06/22/2005 10:42 PM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | SM420 is the 4 spd transmission that was used in the 1/2 ton thru 2 1/2 ton trucks from 1947 thru 1967. It is a desireable tranny for the off-road community due to the 7-1 granny low first gear. I think that it is just about the lowest 1st gear tranny ever built for a production truck. Hope this helps. Garry K in Port Orchard, WA
#46550 06/22/2005 11:16 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Do you have a pic of that SM420? I want one.
#46551 06/22/2005 11:35 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I have 3 of them lying around the place Tab. I will try and get a picture of one tomorrow and e-mail it directly to you. They are still a 1:1 final drive transmission like the standard 3-speed, the only difference is they have the granny gear. Ralph | | |
#46552 06/23/2005 12:06 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My 48 1 1/2 ton can haul as much as you can get on her in granny gear, about 8 tons in second gear, Around 6 tons going flat or downhill in third, and not much more than it's self in forth gear. My V-8 1 1/2 ton truck will haul anything at any speed all day long, Scott | | |
#46553 06/23/2005 2:56 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Thanks Oldtmy! The 1:1 ratio kinda sucks but they have to be better than the crappy 3sp with no syncro in first. Are all the gears syncro? Will it bolt up to my 62, 235?
#46554 06/23/2005 4:11 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Tab - if it's syncro you want just get a later Chev Saginaw 3spd [67+] that has all 3 sync'd - what I've got in my 57 and 58 - same size case, same shift levers, same ratios
Bill | | |
#46555 06/23/2005 4:47 AM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | tab, No, 1st gear is still non-synchro in the SM420, and usually we just start in 2nd, unless hauling heavy loads. But it will let you go with higher gears in the rear, Like 3.08's and still be able to get going off the line, and be able to cruise free way speeds, but I like my 4.11's. May swap up to 3.9's from a 55 gmc later, but for now I will just drive her. Garry K
#46556 06/23/2005 11:11 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Garry I've got an SM420 and 3.08 gears, and I still start off in 2nd almost all the time. Of course its a 1/2-ton truck and rarely carries more than just the driver.
Of course I'm running a GMC 270 instead of the 235 and those extra inches do make a difference.
#46557 06/24/2005 6:22 PM | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Tab, I just sent you a couple of photos of the SM 420 tranny via e-mail. Hope that helps. Ralph | | |
