2 members (Rich'sToys, 1 invisible),
135
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I know I could extend the tube behind the motor and onto the ground but, I know someone on here has done something truly ingenious to route this somewhere other than on the valve cover. Not a great design. Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I will soon be buying 4-5 feet of 1/2" inner diameter rubber tubing and will run it down the starter side of the block. I hope someone shows us a better technique. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I thought it was supposed to be installed at an angle so that it doesn't drip in the valve cover. I'm probably mistaken. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | With a 350 mine would drain right on top of the HEI distributor. I will be routing it under the dash straight over to the passenger kickpanel and down a few inches and out through the firewall just at the toeboard so it will run straight from the firewall/toeboard into the inner fender and drain on the tire.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | And I would send pics but it is all in my head right now.
~Jim
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | I know now why all the valve covers in the junkyard were real rusty in the rear. Jeff | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, and imagine what happens with a 54/55 valve cover that came with slits in the top. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 54Tow...you are not wrong. It does have an angle formed into the hose for the purpose you describe. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The angled side goes towards the driver's side of the valve cover (dripping down that side of the block/clutch housing). This works OK if you have made no modifications (like a dual intake or a remote oil filter near the rear of the block/pan). I do not want any water dripping on my manifolds. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What were they thinking!!!! DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Denny,
Remember, it is just an old work truck. The fact that we love them cannot change what they are. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | That goes for women and pets, too, Lonnie. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, yeah, but, what were they thinkin'!!!! Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | They were thinking, "make do". When we do that in our projects things go bad. I have found if you take a little more time in what you are doing and think about how it could be improved the job looks a bunch better. Yeah it's an old work truck but like the actor said in this latest movie about windshield wipers, " to us it's a Mona Lisa."
~Jim
| | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | Call me sacrilegious, but I am going to fill in my cowl vent and plug the hole. I plan on adding AC, plus I do not want ANY way for water to get back into the cab and rot the floors again. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Where will the water go if you fill in the hole? Also I am sealing the cowl vent (top of the firewall) to keep water etc. out.
~Jim
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Yeah, yeah, but, what were they thinkin'!!!! They were probably thinking it's better to drip on the engine than to drip on your foot.  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But wouldn't you think that someone, after building that truck for nine years would have suggested running a hose down away from the engine??? A buddy of mine that I visit once a week or so is building a 1948 Willys with a complete running gear from a Ranger. I was looking it over the other day and just noticed that the cowl vent didn't have any drain. And the amazing thing was that it wasn't all rusted out. In 60 years you would have thought that they would have left the vent open a few times!
Ahh, but maybe I'm just doin' to much thinkin' about this. Fact is I think, I'll just poke that drain hose back in like it was meant to be and forget about it for the next 58 years. After all, I didn't find any traces of water on or in my 216 and I've been drivin’ her for more than two of those years! Denny Graham Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I think my PO had an idea of diverting the drain but never finished the plumbing as you can see in this PICTURE Just one of the many ingenious modifications I found. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Woody, your in luck, all you need to do is pickup a coupling and a lengthe of 1/2" galvanized water pipe and you're in business. Denny G
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah Woody, your in luck, all you need to do is pickup a coupling and a length of 1/2" galvanized water pipe and you're in business. If you had a mind to, you could even use a tee and make up a run to the radiator then you would never have to top it off in the rainy season. Denny G
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Man Woody, that's ugly...
~Jim
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | If your cowl vent seal failed the water would go into the cab. The purpose of the drain is to give the water a path to escape the vent cavity. My 38 just has a short piece of hose that directs the water down the back of the valve cover.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I was thinking of shoving a length of clear tubing up inside the drain hose and routing it down behind the engine, but never got around to it. I just concentrate on not taking the truck out when it's raining, or making sure the vent is closed if it is raining. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I was looking through the factory assembly manual for the AD's the other day and it actually gives the factory setting for angle and installation of this hose in degrees. One whole page dedicated to just this one operation. | | | | | Joined: Jul 2008 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 28 | Is that Weld Splatter? Did someone work that hard to F it up?
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Is that Weld Splatter? Did someone work that hard to F it up? What exactly are you referring to? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now Brad, ya think you can post a link to that information so we can all find it??? The only reference I find to the drain pipe is section 14 sheet 2.00 and that only covers sealing the tube. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Denny, Here is the photo of the page and the section numbers for your reference. You will notice it calls for a 45 Deg =/-10 setting to miss the valve cover vents. Also Denny the W-1 issue if you look at the next two pictures I posted to my webshots show the indent on the bottom for clearance. This air cleaner did have about an 1/8" clearance for the W-1 on my 216. http://community.webshots.com/photo/2377893620102454676eobulj
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ah yes, thanks Brad. Don't know how I missed that and I looked through the entire book twice page by page. All most all of them that I see have the tube pointing straight down. 45° puts it well over the edge of the cover and drains it right down onto the manifolds, I'd think that would be just about as bad. Denny Graham Sandwich, IL
