2 members (Steelonsteel, klhansen), 105 guests, and 3 robots.
Topics128,261
Posts1,058,329
Members48,485
#46328 06/15/2005 9:50 PM
Has anyone ever heard of or used Redline MTL or MT 90 lubricant for trannys and diffs? I heard its a great product and I'm thinking of using it for my '54 3/4 ton 4 speed, 4.10 rear end as well as on my '69 datsun roadster (with a bad 2nd gear syncro).
Any input is greatly appreciated.
#46329 06/15/2005 9:54 PM
For what it's worth---I think it would be a good product. I looked it up the other day in relation to a similiar topic. I had used GM's synthetic oil for limited slip differentials in a 86 Sentra with that bad 2nd gear! Fixed it up fine and it's had about 20000 miles trouble free!
Cheers, George
#46330 06/16/2005 8:20 AM
A friend of mine swore by it;he used it in his "Cannonball" Chevy Camaro that ran an open road average of 170 mph before it holed a piston near Atlanta,Ga.(I guess he shoulda used it in the engine too)
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#46331 06/16/2005 9:21 AM
stp at 20 percent in your tranny will make 2nd gear stop grinding worked for me on a muncie
#46332 06/16/2005 11:05 PM
32fire2, pardon my ignorance but could you explain your post about STP? Is it 20% of the gearbox capacity or is it 20/80 mixture? Guess they are the same aren't they? I need something to help my 2nd gear synchro. Thanks.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#46333 06/17/2005 3:21 AM
Anonymous
Unregistered
Anonymous
Unregistered
You mean by changing my tranny oil to something else it will help the gear grinding? (my second is bad aswell) Where can you get this redline stuff? Thanks
#46334 06/17/2005 3:49 AM
I've used MolySlip in trans/rear gears before, but if you've got bad parts lube won't fix them, especially worn syncros - and 'gear grinding' beyond worn syncros is the driver and/or clutch!
#46335 06/17/2005 5:30 AM
O the wonderful fix ups in a can.
dan-pa
#46336 06/17/2005 2:21 PM
Articat, you can run a search for redline on the internet. On their wev site there is a tab for dealers, and you input your zip code. It will tell you stores that sell the stuff. It may not completely cure the sloppy transition to 2nd but from what I hear it should help a lot. I should have this done in the next couple weeks and I'll let you know.
#46337 06/18/2005 7:20 PM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks tlorber! I will check into it.
