3 members (FAST55, GRNHydra, Wally / Montana), 93 guests, and 6 robots.
Topics128,077
Posts1,056,014
Members48,433
#462612 10/18/2008 3:01 AM
Got the cab back on the frame today but the cab mount kit that I got from JCarter seems to be a bit on the short side. I mean the rear cab mount bushing (with metal housing) is about 1/2 inch short. Has any one run into this problem? My original mounts are steel wrapped rubber and extremely worn but correct height, when I got the kit (quite while back) I noticed the difference but stashed them away. I can make a poly bushing to make up the difference but was wondering if anyone else had ordered this kit and run into the same problem? If so, speak up and I will let JCarter know they have a problem.
1937 Chevy 1/2-Ton
cb205 the kit you ordered? I was looking at that one
Yep that is the one.
I went back to my old receipt and it states 39-46 pick up/large truck. But the on line catalog states "partially fits 34-38"
I guess that bushing was the one exception.
1937 Chevy 1/2-Ton
