| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Got the cab back on the frame today but the cab mount kit that I got from JCarter seems to be a bit on the short side. I mean the rear cab mount bushing (with metal housing) is about 1/2 inch short. Has any one run into this problem? My original mounts are steel wrapped rubber and extremely worn but correct height, when I got the kit (quite while back) I noticed the difference but stashed them away. I can make a poly bushing to make up the difference but was wondering if anyone else had ordered this kit and run into the same problem? If so, speak up and I will let JCarter know they have a problem. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | cb205 the kit you ordered? I was looking at that one | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Yep that is the one. I went back to my old receipt and it states 39-46 pick up/large truck. But the on line catalog states "partially fits 34-38" I guess that bushing was the one exception.
