2 members (Wooley, Hotrod Lincoln), 81 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
hello:
i would like to replace the carb on my 65 ss with the original 283 motor as it is being unreliable. all i want is a simple basic reliable efficient non tempermental carb. i have been hearing all sorts of opinions "edelbroc carter rochester etc."
any advice as to what would be my best option?
also who would be my best resource for the carb. is this something that i can get at any good auto parts store or do i need to go to a specialty outlet like summit,lmc etc.?
thank you
Why not just put another of what was on it originally? I grew up on 50's and 60's Chevys and don't recall the carbs being a problem.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
43 years old could be the problem, worn throttle shaft/baseplate can cause idle problems and acceleration issues. but old G.M. carbs were basic and reliable. what do you mean by tempermental?the carb maybe the byproduct of the problem not the problem itelf.
Need a bit more info. Car? Truck? 2 or 4 bbl? Reman Rochesters are available (Napa has them for certain). Alternatively, at least with 4 bbls, you could go Edelbrock, which is more or less a fancy Carter AFB. Or you could overhaul the existing carb, if it isn't too worn out.
Bill Burmeister
the truck is a 65 short step chevy.
i think the existing carb is a rochester 2bbl. the prior owner said it was recently rebuilt but upon my receipt of the vehicle
it was leaking gas from the carb. rather than fool around with another rebuild i would rather have a new one. someone today mentioned a holly from summit??
thank you
It might of been rebuilt but where is it leaking? Out the shaft, accelarator pump, over the top of the float bowl? If it is out of the float bowl area it might be loose screws on the top of the carb. that were not tighten down. Internaly could be float stuck or bad float. May be the screws holding the float bowl to bottom of the carb. are loose. I believe there new manfacture carbs still avaible at the Truck Shop, Jim Carter or maybe Napa for a reman. Rochester's I believe came standard.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Riding in the Passing Lane
The little Roch. 2 barrel that they come with is a good reliable carb but like any carb it must have good clean gas going to it. A small foriegn particle can get in the needle & seat & cause flooding & gas leaking out the throttle shafts. For a off the shelf carb the Edelbrock performer is hard to beat. If you have a 2 barrel you will need a different manifold. If you have a 4 barrel you will need a plate to block the heat passages in the manifold. A place like Summit or Jegs has the best price on that sort of thing. The reman carbs you get at the parts stores about half the time dont work right. Dont give them your old one till the job is done & you are satisfied with it.
1972 Chevy c10 Cheyenne Super
If you can.t change the intake manifold yourself you are best off repairing the original or getting a matching replacement. The only advantage of a 4 barrel is more power. also check the rest of the engine. If the points &/or timing are off it can be blamed on the carb.
Carburetion specialist
The first step is to determine exactly what you have. Chances are if the carb is original, it is some form of Rochester 2-bbl. The Rochester 2 barrel carburetor is one of the most reliable and "bulletproof" carbs that has ever been built anywhere at any price.
It may need a little TLC, or you may have other problems. Why not specify symptoms, and exactly which carburetor. Might be an easy fix.
Jon.
The Carburetor Shop
thank you
If you want reliability and a "nontempermental" carb, you definately don't want a Holley.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
