3 members (39suburban, Chip O, Goach2), 161 guests, and 3 robots.
Topics128,186
Posts1,057,305
Members48,467
Apprentice
Apprentice
I'm not sure what I just got myself into, but I picked up a 1955 Chevy dumptruck for $400. Barely any rust at all. The previous owner used it to drag his horse arena. It has an electrical issue that it doesn't want to crank over. He said it runs well when it does run and the dump bed works. The tranny may need to be rebuilt though. At the very least the shifter is very very sloppy. It rotates around on itself. I can't really push it side to side. When he put a new starter in it Pepboys said the starter is off of a 1971 straight six, so I'll have to investigate what year motor is in there. I'll post up pics tomorrow. I can't wait to tear into this for my winter project. Woohoo!!!
1955 Chevy Dumptruck
2003 Chevy 2500HD: Crewcab, Longbed, 2wd, 6-speed manual
2005 Pontiac GTO: 500hp and a transbraked TH400
Right on hope you have fun with your project and I for one will be looking forward to some pictures
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
My '67 GMC pickup had a sloppy shifter like you describe. The problem was on top, where the lever went into the transmission. I don't recall if it was the lever itself, or the housing where it went into. (This was probably 15 or more years ago.) At any rate, my brother, who is a welder, was able to build up the area that was worn, and it's worked good ever since.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Yep, the alignment pins on the tranny cover and the grooves in the shifter may be hogged way out. I found some grade-8 allen head screws to replace the pins and welded & reground the grooves. Shifter works great now.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
Apprentice
Apprentice
Looks like you got a good deal! smile
Apprentice
Apprentice
Took the shifter out and there is one slot on either side of the shifter that is "hogged out". Looks like I need a welder/machinist or just a new shifter. I'll take some pics of the shifter later today.
Oh yeah:
IT RUNS!!!! Just a mis-wired ignition switch. The bed goes up and down just great. The motor has a sort of clanky/grindy sound to it that I hope is just the water pump. But for $400 who can complain if I have to rebuild the engine.
That is a sweet deal! Very cool. cool
Looks like it has a later model 6 cylinder, such as a 292, etc. That makes sense with what the owner told you about the 1971 starter.
Welcome to the bolt! And again, great find!
Jeff
My 1953 Chevrolet
1947.1 Gallery
Apprentice
Apprentice
Just ordered a new shifter from Novak. It all should be here on Friday. Hopefully all the gears work. I'm keeping my fingers crossed. I just have to drill out the top piece where there were a couple of cap screws loosely placed in the dowel pin holes and tap them to thread in.
Nice looking truck! And the price was definitely right.
And by the way----Welcome to the Bolt!! (Forgot to mention that yeaterday!)
Rich
1947 Loadmaster
That's a 250 cubic inch, not a 292. The side tappet covers are short. If they were tall that would = 292.
Picture of a 292
Apprentice
Apprentice
So it's a 250 then. Thanks. Next up on the list is electronic ignition, a new waterpump, and an electric fan. Oh yeah, and rewire the whole truck. The wiring is a horrible mess. I'm not looking forward to it. I may just pay my buddy to do it. I hate wiring, grrrr. But on a plus note the oil pressure and charging gauge still work. I don't know how accurate they are, but my at idle oil pressure is 30 and it goes up to around 40-45 when I rev it.
I'm pretty sure the modern electronic ignitions are a simple drop-in....as long as you're already on 12-volt.
The "Rat Rod" folks would tell you to leave the paint alone. They work hard to get that kind of aged patina.
Apprentice
Apprentice
Paint and body is definitely last on my list. I need to get it running good in all gears and rewire the truck. Then maybe I'll sand or media blast the heck out of it and paint it. It's all just surface rust right now and since I'm in Arizona I am in no hurry to get to it. As it sits now with a good running engine and new wires this truck would last another 50 years easy.
Apprentice
Apprentice
Nice Buy!
I love the "patina" - I'd almost just git it safe to drive and some new tires and have some fun, you can always paint it next winter!
Apprentice
Apprentice
Paint is last and most likely next winter. The new tires are going to kill my budget, lol. It's hard to spend that much money when the truck was initially $400.
Sure is purty, great find!
:P
Apprentice
Apprentice
Thanks! Although I'm starting to realize how many multiple thousands of dollars are going to get "dumped"(insert knee slapping pun) into the truck. It's gonna be sweet when I'm done though.
1 Offline
cool truck! tires and brakes are the usual reason these big bolts get parked and then sold.
Apprentice
Apprentice
The brakes work good, just haven't done an inspection of them yet. Some Nankang 8.25-20's are $160 each, so not to bad. I haven't gotten a price on the tubes or mount cost though. I found a local old tire shop that's been in business for about 70 years that can handle the multi piece wheels.
Very Kewl looking truck.
JC Offline
Yep, nice truck! The motor is a 250 or smaller. The 292's had fuel pumps in the middle of the block and 6" high pushrod covers.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
Former Workshop Owner
Very nice!! What a great deal. thumbs_up
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Big Bolt Forum Co-moderator
That is a great deal....... The truck gods were smiling on you! Very cool truck.
1948 Chevy 2-Ton
