1 members (J Lucas), 85 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#460019 10/10/2008 2:00 AM
why doesnt my brake pedal come back , is there suppose to be a spring on it to spring back when your foot come off the pedal ?
care to chat write back
mickster #460023 10/10/2008 2:05 AM
What year, model, make of truck?
On 47-54 Chevrolet & GMC trucks there is a pedal return spring.
(click on the photo if it looks small in your browser)
Riding in the Passing Lane
Yes there is a return spring. All parts stores have universal ones that have a long wire on one end. It can be cut to size & bend a hook in it. It,s also possible they shaft at the end of the pedal is sticking & needs greasing.
1972 Chevy c10 Cheyenne Super
its a 1947 second series or 48,49-54, 3/4 ton
mickster #460360 10/11/2008 2:32 AM
If its like my 52 (and I think it is) there should be a "short piece" that is part of the pedal that sticks down....has a hole in it and the spring should hook and then go to a hole or bracket on the chassis. I think the original one was "sort of a long one" with a straight piece of wire also. In other words trhe spring was a "two part" spring. Hope this helps..and as George says see if you can shoot a little grease in the fitting that should be on the pedal where it pivots on the master cylinder.....heck, a screen door spring would even work.
The "rod" and return spring are shown at the link above.
The "short piece" with a hole for the "rod" (that Alvin refers to) is in that picture. The grease fitting is also shown.
