0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | why doesnt my brake pedal come back , is there suppose to be a spring on it to spring back when your foot come off the pedal ?
care to chat write back
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year, model, make of truck? On 47-54 Chevrolet & GMC trucks there is a pedal return spring. (click on the photo if it looks small in your browser) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes there is a return spring. All parts stores have universal ones that have a long wire on one end. It can be cut to size & bend a hook in it. It,s also possible they shaft at the end of the pedal is sticking & needs greasing.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | its a 1947 second series or 48,49-54, 3/4 ton
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If its like my 52 (and I think it is) there should be a "short piece" that is part of the pedal that sticks down....has a hole in it and the spring should hook and then go to a hole or bracket on the chassis. I think the original one was "sort of a long one" with a straight piece of wire also. In other words trhe spring was a "two part" spring. Hope this helps..and as George says see if you can shoot a little grease in the fitting that should be on the pedal where it pivots on the master cylinder.....heck, a screen door spring would even work. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The "rod" and return spring are shown at the link above.
The "short piece" with a hole for the "rod" (that Alvin refers to) is in that picture. The grease fitting is also shown.
