4 members (Bill Hanlon, baldeagle, Greg_H, Guitplayer), 83 guests, and 1 robot.
Topics128,037
Posts1,055,469
Members48,424
#455658 09/24/2008 9:13 PM
Does anyone have experience with replacing your points with the Petronix Ignitor I system?
Did you replace your coil with the Flamethrower coil, too?
TIA
Dennis
oldbluetruck #455660 09/24/2008 9:23 PM
i have both in my '72 GMC V6, they work good as long as you don't get in hurry to start it and forget to put the rotor back in.
47chevy6400 #455684 09/24/2008 10:49 PM
Do a search on Pertronix and you will find a lot of opinions and even some information from people who have used Pertronix units.
Search in this forum and in all forums.
tclederman #455773 09/25/2008 2:12 AM
I haven't put one in the truck yet but have been running one in my 60' MGA for about 5 years now. I even bought an extra and extra coil as a back up. I haven't had any need for the spares. The hotter coil allowed me to increase the plug gap some and it made it run like a top. I have been very happy with the choice and will put one in the 235 when I get that far down the line.
neilroy #455792 09/25/2008 3:13 AM
I replaced the points in my 1960 235 with the Ignitor 1 about 3000 miles ago and have had no problems. I'm running a stock coil and plugs with the stock gap. Plugs look like they did the day they were installed.
Like the others, I carry a set of points and the other components removed from the distributor when I installed the Ignitor. Would highly recommend the Ignitor 1.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Fla54Chevy3100 #456715 09/28/2008 10:41 PM
I have it on my 1954 261 engine.I'm using the 40,000 volt flame thrower coil. It works wonderfully,keep in mind that there is a 6 volt and a 12 volt pertronix ignitor system available.
1951 3100 Chevrolet
bowtietim #458180 10/03/2008 2:11 PM
Ive had a set on my 57 truck for about 5 years and lots of miles, nary a glitch yet. Works well.
dg
DGERTH #458214 10/03/2008 3:24 PM
I switched my 67 Triumph Trophy over to Boyer Electronic basically the same set up a few yrs. ago ...doin away with dual points an all that stuff ...man for old engines it makes a world of difference!
I like em.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #466716 10/31/2008 8:15 AM
I've been running the Petronix Flame Thrower ignition coil and the Petronix magnetic gizmo in place of the points in my 62 Chevy C-10 235 for 7 months now.. Awesome results.. Also I switched out the generator to an alternator at the same time.. No complaints and less maintenance.. Now all I do is go into the valves now and again and set those and change the oil.. I use a 45 thousands plug gap and it runs like a top.. Easy peezy japaneezy.. Definitely a good move..
62 Chevy windshields rock...!!
