| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Does anyone have experience with replacing your points with the Petronix Ignitor I system?
Did you replace your coil with the Flamethrower coil, too?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i have both in my '72 GMC V6, they work good as long as you don't get in hurry to start it and forget to put the rotor back in. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do a search on Pertronix and you will find a lot of opinions and even some information from people who have used Pertronix units.
Search in this forum and in all forums. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I haven't put one in the truck yet but have been running one in my 60' MGA for about 5 years now. I even bought an extra and extra coil as a back up. I haven't had any need for the spares. The hotter coil allowed me to increase the plug gap some and it made it run like a top. I have been very happy with the choice and will put one in the 235 when I get that far down the line. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I replaced the points in my 1960 235 with the Ignitor 1 about 3000 miles ago and have had no problems. I'm running a stock coil and plugs with the stock gap. Plugs look like they did the day they were installed.
Like the others, I carry a set of points and the other components removed from the distributor when I installed the Ignitor. Would highly recommend the Ignitor 1.
Dave | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have it on my 1954 261 engine.I'm using the 40,000 volt flame thrower coil. It works wonderfully,keep in mind that there is a 6 volt and a 12 volt pertronix ignitor system available. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | Ive had a set on my 57 truck for about 5 years and lots of miles, nary a glitch yet. Works well. dg | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I switched my 67 Triumph Trophy over to Boyer Electronic basically the same set up a few yrs. ago ...doin away with dual points an all that stuff ...man for old engines it makes a world of difference! I like em. Tim | | | | | Joined: Jul 2008 Posts: 71 New Guy | | New Guy Joined: Jul 2008 Posts: 71 | I've been running the Petronix Flame Thrower ignition coil and the Petronix magnetic gizmo in place of the points in my 62 Chevy C-10 235 for 7 months now.. Awesome results.. Also I switched out the generator to an alternator at the same time.. No complaints and less maintenance.. Now all I do is go into the valves now and again and set those and change the oil.. I use a 45 thousands plug gap and it runs like a top.. Easy peezy japaneezy.. Definitely a good move..
62 Chevy windshields rock...!!
