| | | Forums66 Topics128,197 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 11 New Guy | | New Guy Joined: Sep 2008 Posts: 11 | Any opinions out there? I'm doing my frame and have been looking at all 3 products. Does anyone have a real strong preferance to any one of them? Or any opinions on rust conversion as opposed to rust encapsulation? I'm sure this topic has been covered before, but I figured since time has passed since the last post, if anyone had any failures since then. Thanks | | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | Zero rust has worked very well for me. I found it nicer to work with that POR 15. Check out the write-up in the tech section.
Dave 66 GMC- father /son project with the "GMC KID" 36 Chevy PU- 4x4 lifetime project 64 Skylark- wife says its hers
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Same here on the Zero Rust, working on my frame now, hope to paint it week after next. I did my inner fenders and under the running boards with ZeroRust, and they came out good, easy to spray on with a HVLP gun. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I've only used the Eastwood Rust Converter and I like it. It's water based and seems to do what it's advertised to do and now it's available in aerosol which I have yet to try.
I've also used their Rust Encapsulator.
I'm very happy with those products. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have only used POR15 and really like it. Yes, its messy, smelly will dry out on you if not careful plus be sure to use a respirator if spraying and some sort of mask if brushing it on. I really like the finish on it and its tough as nails. Do a search on POR15 and enjoy the reading for ah hour or so. Be sure to follow safety directions on any of it! | | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | I used the rust conversion system from Eastwood. I found that if you already have some rust, it works great in converting it and then leaving a zinc phosphate like finish that you then can paint. Just seemed to me that if I was gonna paint over some rust I might as well try and kill it off first. I think you will get the same results with all three but like Woody said, you cant beat the water based nature of the product. Ralph | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i just ended up buying what was easiest for me ... POR15 they all work.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
