3 members (Wayne67vert, Rusted Nut, SmalltownTRKGuy), 106 guests, and 5 robots.
Topics128,184
Posts1,057,195
Members48,465
Any opinions out there? I'm doing my frame and have been looking at all 3 products. Does anyone have a real strong preferance to any one of them? Or any opinions on rust conversion as opposed to rust encapsulation? I'm sure this topic has been covered before, but I figured since time has passed since the last post, if anyone had any failures since then. Thanks
Zero rust has worked very well for me. I found it nicer to work with that POR 15. Check out the write-up in the tech section.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
Same here on the Zero Rust, working on my frame now, hope to paint it week after next. I did my inner fenders and under the running boards with ZeroRust, and they came out good, easy to spray on with a HVLP gun.
I've only used the Eastwood Rust Converter and I like it. It's water based and seems to do what it's advertised to do and now it's available in aerosol which I have yet to try.
I've also used their Rust Encapsulator.
I'm very happy with those products.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I have only used POR15 and really like it. Yes, its messy, smelly will dry out on you if not careful plus be sure to use a respirator if spraying and some sort of mask if brushing it on. I really like the finish on it and its tough as nails.
Do a search on POR15 and enjoy the reading for ah hour or so. Be sure to follow safety directions on any of it!
I used the rust conversion system from Eastwood. I found that if you already have some rust, it works great in converting it and then leaving a zinc phosphate like finish that you then can paint. Just seemed to me that if I was gonna paint over some rust I might as well try and kill it off first. I think you will get the same results with all three but like Woody said, you cant beat the water based nature of the product. Ralph
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
i just ended up buying what was easiest for me ... POR15
they all work.
Jim & Caroline
