1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#454613 09/21/2008 8:07 PM
iam new to this but my front brakes , driverside leak and come out on the rim, everything is tight so it must be leaking in the hub, i took the front hub off and looks like the brake fluid comes out the cylinder somewhere, where do i get it fixed or where do i get a new one ?
care to chat write back
Riding in the Passing Lane
You have a leaking wheel cylinder. You have to put a repair kit in it or put on a new cyl. If you are not qualified to do it yourself you will have to find a shop or mechanic that can. The 1950 on back trucks used Huck brakes. they are kind of ornery to work on.
1972 Chevy c10 Cheyenne Super
where do i find the repair kit ?
A parts store, look for the oldest guy in there.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
thanks , and there is one older guy there too................?
If it were me, I would not do just one wheel cylinder. At a minimum I would suggest doing both sides but really you should be looking at the whole system. If the whole system was fairly new and one cylinder failed then that would be a case to do just one.
1951 1 Ton Completed
Part numbers for Raybestos 1947 Chevy Half Ton Wheel Cylinders;
WC3406 Front
WC3396 Rear
They do not list a repair kit.
Any good parts store has or can get them. Not cheap.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Going by current DOT and MAP regulations for repair shops, hydraulic components (wheel cylinders, calipers, and hoses) should always be replaced in pairs. This both due to potential failure of the side not replaced and to maintain even braking power on boht sides of the axle (worn vs new parts).
Bill Burmeister
Napa repair kit. Part number 8.
