1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | iam new to this but my front brakes , driverside leak and come out on the rim, everything is tight so it must be leaking in the hub, i took the front hub off and looks like the brake fluid comes out the cylinder somewhere, where do i get it fixed or where do i get a new one ?
care to chat write back
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You have a leaking wheel cylinder. You have to put a repair kit in it or put on a new cyl. If you are not qualified to do it yourself you will have to find a shop or mechanic that can. The 1950 on back trucks used Huck brakes. they are kind of ornery to work on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | where do i find the repair kit ?
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | A parts store, look for the oldest guy in there. Scott | | | | | Joined: Jan 2007 Posts: 117 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 117 | thanks , and there is one older guy there too................?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it were me, I would not do just one wheel cylinder. At a minimum I would suggest doing both sides but really you should be looking at the whole system. If the whole system was fairly new and one cylinder failed then that would be a case to do just one. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Part numbers for Raybestos 1947 Chevy Half Ton Wheel Cylinders; WC3406 Front WC3396 Rear They do not list a repair kit.
Any good parts store has or can get them. Not cheap. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Going by current DOT and MAP regulations for repair shops, hydraulic components (wheel cylinders, calipers, and hoses) should always be replaced in pairs. This both due to potential failure of the side not replaced and to maintain even braking power on boht sides of the axle (worn vs new parts).
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Napa repair kit. Part number 8. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
