6 members (Brian Moore, ndkid275, Otto Skorzeny, klhansen, Chip O, Bwana-Jim), 83 guests, and 1 robot.
Topics128,034
Posts1,055,542
Members48,425
#45400 05/16/2005 3:29 PM
GOOD MORNING,
I PUT IN A '55 235 THAT'S REBUILT IN MY '48 CHEVY HALF TON... AND NOTICE THAT THERE'S NO TIMING NOTCH ON THE HARMONIC BALANCER/PULLEY
IS THERE ANOTHER MARK USED TO FIND TOP DEAD CENTER?
THANKS- ALMOST READY TO GET BACK ON THE ROAD!
#45401 05/16/2005 3:58 PM
All the old sixes have the timing mark on the flywheel. You'll see it through a hole in the bellhousing just above the starter. In this hole is a pointer which will line up with a ball in the flywheel when at TDC.
1946 1/2-Ton Chevy
#45402 05/16/2005 4:04 PM
too early to be yellin!!
start the timing by setting 'octane selector' on dist to 0 - the timing mark is a little ball on the flywheel, seen thru the opening in the pass side flywheel cover
#45403 05/16/2005 4:05 PM
thanks so much, I have learned something!
