0 members (),
182
Mod | | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45400 05/16/2005 3:29 PM | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | GOOD MORNING, I PUT IN A '55 235 THAT'S REBUILT IN MY '48 CHEVY HALF TON... AND NOTICE THAT THERE'S NO TIMING NOTCH ON THE HARMONIC BALANCER/PULLEY IS THERE ANOTHER MARK USED TO FIND TOP DEAD CENTER? THANKS- ALMOST READY TO GET BACK ON THE ROAD! | | |
#45401 05/16/2005 3:58 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | All the old sixes have the timing mark on the flywheel. You'll see it through a hole in the bellhousing just above the starter. In this hole is a pointer which will line up with a ball in the flywheel when at TDC. | | |
#45402 05/16/2005 4:04 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | too early to be yellin!! start the timing by setting 'octane selector' on dist to 0 - the timing mark is a little ball on the flywheel, seen thru the opening in the pass side flywheel cover
Bill | | |
#45403 05/16/2005 4:05 PM | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | thanks so much, I have learned something! | | |
