1 members (JW51),
115
0
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Should the Hood sheet metal be away from the Hood reinforcement cross member or am I missing something that goes in between to fill the gap. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you want a quick answer, tell us what year make and model. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | David Sr,
Is this on your '51 pickup? On my old truck there was a piece of rubber mashed in there from factory (I assume). Over the years it has turned to black goo.
I don't know if this material was some type of bonding tar or just a thing piece of material to keep chafing and squeaking down. I'm not much help...maybe the correct answer will be along soon.
Stuart | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Stuart
Thanks, yes my 51 chevy | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | David, Yes that is how it is, the floppy wings you are refering to just set on the cowl seal and when ya close a correctly adjusted hood they lay tight on that seal an that is how they were made. If ya need some pics of the hood and cowl seal let me know. Tim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim,
I also thought as you did regarding what was being asked.
I now think, however, that David is referring to the brace attached to the underside of the hood, near the rear of the hood. Most of my hoods had some sort material, as described by Stuart. One of my hoods had a very creative and innovative former owner and between that brace and the hood were strips of 1/8" masonite (and the gooey/rubber-like material).
Tim | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Tim,
That is the brace, the one under the hood. I beleave Tim(Sw) is thinking of the same brace Because I was thinking the same thing for when the hood is closed it has that room to move if it does hit the cowl seal before the hood is closed all the way. But your saying there is some type materal under neath. would this be glude in place or just pushed in and held that way. Any I deal what to use to replace this gooey rubber ?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Boy howdy, it would be great to get a picture of this thing. You really get a bunch more answers if you post a picture of you problem area.
~Jim
I am going to have eat come crow here! My truck is a 55/1st 4400. The hood is in the basement blasted and primed. I just went down and looked at the rear hood brace. There is no material between the brace and the skin of the hood. There is no trace of anything and I didn't remove anything (that I remember).
The skin is tensioned so that about a 1/4" room exists between bracket and sheetmetal. I remember a thread about this years ago and I thought I recalled hearing about a tar impregnated pad running side to side that was a buffer between the skin and the reinforcing bar. I swear that I have seen that gooey pad on some AD rigs.
Stuart | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | I'm pretty sure there was some sort of rubber/foam between the skin and the brace, but as someone wrote earlier, if your hood is adjusted right, ideally it will be held tight against the hood-to-cab seal. That's all I'm going to use. | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | This issue has been silent. I found this thread looking for same answer but, I am armed with a few facts.
1951 3600 Chevy. Factory assembly manual states you use an "anti-squeak pad" between the "rear reinforcement bar" and the hood sheet metal. An adhesive is used to maintain its location. Mine is all crispy and bubbled.
Anyone use a material for the pad and have a source, name, nomenclature, manufactures, etc?
Thanks | | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | how about a piece of 30# roofing felt paper? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | See our vendors for gas tank pads. Classic Parts of America Part No. 23-325, should work for hood.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
