6 members (WICruiser, 3800GUY, kades51, Paul Mullen, TUTS 59, Ponchogl), 120 guests, and 4 robots.
Topics128,090
Posts1,056,381
Members48,442
#453447 09/18/2008 1:13 AM
Should the Hood sheet metal be away from the Hood reinforcement cross member or am I missing something that goes in between to fill the gap.
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
If you want a quick answer, tell us what year make and model.
David Sr,
Is this on your '51 pickup? On my old truck there was a piece of rubber mashed in there from factory (I assume). Over the years it has turned to black goo.
I don't know if this material was some type of bonding tar or just a thing piece of material to keep chafing and squeaking down. I'm not much help...maybe the correct answer will be along soon.
Stuart
Stuart
Thanks, yes my 51 chevy
David
David,
Yes that is how it is, the floppy wings you are refering to just set on the cowl seal and when ya close a correctly adjusted hood they lay tight on that seal an that is how they were made.
If ya need some pics of the hood and cowl seal let me know.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Tim,
I also thought as you did regarding what was being asked.
I now think, however, that David is referring to the brace attached to the underside of the hood, near the rear of the hood. Most of my hoods had some sort material, as described by Stuart. One of my hoods had a very creative and innovative former owner and between that brace and the hood were strips of 1/8" masonite (and the gooey/rubber-like material).
Tim
Tim,
That is the brace, the one under the hood. I beleave Tim(Sw) is thinking of the same brace Because I was thinking the same thing for when the hood is closed it has that room to move if it does hit the cowl seal before the hood is closed all the way. But your saying there is some type materal under neath. would this be glude in place or just pushed in and held that way. Any I deal what to use to replace this gooey rubber ?
David
Boy howdy, it would be great to get a picture of this thing. You really get a bunch more answers if you post a picture of you problem area.
~Jim
David Sr,
I am going to have eat come crow here! My truck is a 55/1st 4400. The hood is in the basement blasted and primed. I just went down and looked at the rear hood brace. There is no material between the brace and the skin of the hood. There is no trace of anything and I didn't remove anything (that I remember).
The skin is tensioned so that about a 1/4" room exists between bracket and sheetmetal. I remember a thread about this years ago and I thought I recalled hearing about a tar impregnated pad running side to side that was a buffer between the skin and the reinforcing bar. I swear that I have seen that gooey pad on some AD rigs.
Stuart
I'm pretty sure there was some sort of rubber/foam between the skin and the brace, but as someone wrote earlier, if your hood is adjusted right, ideally it will be held tight against the hood-to-cab seal. That's all I'm going to use.
This issue has been silent. I found this thread looking for same answer but, I am armed with a few facts.
1951 3600 Chevy. Factory assembly manual states you use an "anti-squeak pad" between the "rear reinforcement bar" and the hood sheet metal. An adhesive is used to maintain its location. Mine is all crispy and bubbled.
Anyone use a material for the pad and have a source, name, nomenclature, manufactures, etc?
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
how about a piece of 30# roofing felt paper?
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
Sir Searchalot
Sir Searchalot
See our vendors for gas tank pads. Classic Parts of America Part No. 23-325, should work for hood.
Denny G
Sandwich, IL
