8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup),
111
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Hi All,
I bought 90 AMP fluxcore welder from HF and I tried hard enough to weld anything, all it does is sputters all over. Since I am new to Welding I thought I am the problem, but my friend who is a certified welder and welded heavy equipments says that one is useless.
I wanted to weld sheet metal, what is you guys opinion and what is a decent affordable welder for sheet metal welding. Please advise
Ganesh | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have a $120 Flux core I bought at HF about a year ago. When I first got it I thought it was a piece of crap,(and I still do) but I didn't want to admit defeat so I kept playing with it and I have got it to work acceptable now. It does splatter a lot but I grind the welds down anyway, so that isn't a problem for me. I have welded both cab corners,both rocker/steps, hinge pillars, patch panels on my fenders, etc with little problem. The thing I don't like is I have to go over the welds a second time in some areas because of tiny pinholes in the weld when I but weld. Time consuming, but cheaper than buying a new welder. Even though I can get buy with the HF welder, if you want a good one don't look in HF. I haven't priced a good one but I am sure someone here can give you some good advice. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks Alan that is exactly what I felt, it should be usable because how will company make a welder which cannot be used at all
Ganesh | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Hobart, Lincoln and Miller all make good welders. As for affordability it really depends very specifically on what it will be used for. They all make cheap and they all make expensive units, just matters on what your willing to pay and what you consider acceptable work.
Jeff | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I don't know how you welded cab corners with a flux welder. I tried to weld a patch on my tailgate and all it did was burn a hole.
I have a Lincoln 100 and I have purchased the MIG kit for it.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I have a clarke (I think it is the 180 model) and am pretty happy with it so far.
Ed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | smokey_truck,
Just for the record, Jim Bow speaks the truth...it isn't the welder or the fact it came from Harbor Freight, it's the process that is difficult with sheet metal.
Flux core is a tough gig on thin materials, solid wire with shielding gas (MIG) would make life much easier for you, but your bank account wouldn't be as fat.
Stuart
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | Thanks for suggesstion guys, looks like I should look for MIG with Shielding gas
Ganesh | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Go HOBART!!!!!!!  Can you tell I'm a happy Hobart owner?
-Matt
| | | | | Joined: Oct 2007 Posts: 388 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 388 | What model did you buy in Hobart? my budget allows on Hobart 140 MIG and runs on 115V | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | I bought the Handler 125 and later upgraded to Mig with a mig kit.... In retrospect, I should have gotten the bigger 140 unit as it is available in 240v which yields higher duty cycle......
-Matt
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I have been using Miller wire welders for 20 years. We have a 200 a 250 and a flux wire feeder on a Trailblazer 440. I recently bought a Hobart 140 and run .023 wire with straight co2 Because I don't want to take my toys out to the shop and I got tired of lugging a 200 with a big bottle to the house, even though I have a 50 amp plug. I am astounded how easy it is to weld thin stuff like body panels. I haven't really read the book, but I would be hesitant to use it for anything over 1/4 inch. But for thin stuff, I think I could weld two tin cans together. I feel like I got the best deal on the 140 on Amazon.com | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I don't know how you welded cab corners with a flux welder. I tried to weld a patch on my tailgate and all it did was burn a hole.
I have a Lincoln 100 and I have purchased the MIG kit for it. Here is a cab corner I welded with a 90 amp HF flux core MIG. It is very time consuming. A better welder would be much faster. CAB CORNER 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have used hobarts for years as well and have always been pleased with them. i think it's good advice to go with a 220 unit if you can at all. i had a 150 or 160 hobart handler that was 220 and used it for years. you have the flexability to weld thin body panels or thicker steel as well. i haven't used the flux core stuff a lot but i think it usually looks like it has pin holes in the weld, structurlly it's prob as good but it you wanted it to be water or air tight i don't think it's as good. i have welded body panels 15 -20 years ago when i was in high school with a arc welder as a slow process of start and stop before it burns thru but i wouldn't do it again. but you know, whatever floats your boat. it's hard to beat a good gas shielded mig welder for body work.
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I bought a Hobart/Miller 135 a few years back. Using the 75/25 gas it makes a quality weld with minimal splatter. Complete with a 10 lb. spool of wire and the bottle of gas it was $750.00, I am completely satisfied with it. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I think it is difficult to get one welder to do it all. I used a millermatic 200 for everything except real thick stuff for 20 years. After getting a Hobart 140 with .023 wire strictly for thin stuff, I wouldn't even attempt to weld patch panels with my 200 any more. The 140 is just so much easier. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | CO2 works best on body parts as it cools the weld area, Argon gets a better penetration for heaver stuff. Inner shield sorta defeats the reason for having a mig unless you are welding outside or very high amperage. | | | | | Joined: Apr 2006 Posts: 15 New Guy | | New Guy Joined: Apr 2006 Posts: 15 | at you local welding supplier theysometimes have used equipment and all the advice you need | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | HF welders are crap, I have sold over 100 of them in an aution business I had, and I am a certified welding inspector and welding teacher. The midline homeowner century welders are not bad, I have one that welds SMOOTH with flux core. Lincoln, Hobart, and the others are better.
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Hobart Handler 187 and big brother 210 are very nice welders for the money and will dial down for sheet metal as well as do the thick stuff. Some say these have a better arc than the Millers do, but I've only read that. I like my 187 very well.
Both are 220v machines.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | I have a century 155g from cost co (ware house super store) i have had it for 10 years and works great for $399.The lincoln 110 weld paks are nice too. | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | I have a millermatic 175 and it works good
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
