2 members (Goach2, Southerntruck), 122 guests, and 5 robots.
Topics128,185
Posts1,057,274
Members48,467
They sell standard, .010 and .020 oversize pins. I have a micrometer. What should the nominal diameter of the pin be?
Keith
3B Online: Content
3 Online: Content
Hy Slickriffs, according to my Moog catalog the standard diameter is .9210" X 5.640" long, hope that helps.
3B thanks-
I'll mic it up when I get home-from memory it's
somewhere around there..
Keith
Keith,
With all your front end work going on, I know you realize this already..you will only want to replace the old pin with a new pin of the same diameter if it fit the axle eye properly. If the old pin mic's standard but fit the eye poorly, a oversize is in order.
I assume you are merely trying to determine which size you have now.
Stuart
Thanks Stu-I actually haven't thought it out that far..
so thanks for the reminder.
Keith
I was surprised that I didnt need oversized pins in my COE when I just overhauled it. I pushed the pins out and cleaned up the eye in the axle and the pins fit pretty darn snug in there. Just a touch of play, but almost non exsistant. I figured after 60+ years it would be worn out.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Stu/Jeff/3B
Just came in from the garage..Mine mic .921..Good number 3B
The axle that Sid dropped came from Cal..from an ad I ran in the "Parts wanted" forum here. He sent the 3/4 ton axle to Sid and the spndles to me..He(brian)was nice enough to include the original kingpins etc. I was amazed that they sill had a mirror finish. I've seen articles where they're removed and completely rusted..These are probably re-useable but for $45 what the hey... I tried them in the axle and they're a little loose for the first 1/4 " and then snug up to a point where you have to tap them back out. So I think I'm good to go..
On the other hand: On the axle that's currently in the truck.. The drivers side hasn't taken grease in 30 years..man that statement makes me feel old..
Thanks gents..I learned sompin today..
Keith
