4 members (Steelonsteel, 66flea, treegrower, Otto Skorzeny), 50 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#449253 09/05/2008 10:08 AM
is it possible and safe to repair a cracked balancer? its cracked on the outer edge. a u shaped crack.
also can a double groove 250 balancer work on a 230?
thanks
-chris-
If you want to get it repaired, give the Damper Dudes a call.
Damper Dudes
6180 Parallel Rd
Anderson, CA 96007
530-365-2144
1-800-413-2673
Holy cow - $150 for a HB for a 235!
As for repairing yours, it would help if we had a picture.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
The dampner is not something I would personally mess with. An exploding one does huge damage and can ruin your crank.It's worth the money to me to have one replaced or properly repaired.
Drew
I bought one from Langdon's awhile back for my 235, think I paid $45 bucks for it....no problem with it..
looked like a new one..
Redryder pix
My Hotrod
HERE'S a picture of the damage. He sent me a photo so I could post it for him.
Woody
Door Art Collection
I think Id opt for finding a decent used or new one. Id hate to have something come apart under the hood at 2500 RPMs... eek
My 1953 Chevrolet
1947.1 Gallery
mine did, that is why I replaced it........I was lucky, no damage to the radiator or fan........the thing just spun off and dropped down below the radiator.
I was cruising about 65 when I heard a noise.. did not think anything of it because an 18 wheeler had just passed me, I then heard a strange noise, looked at my temp gauge, it had started to warm up... pulled off the hiway, open the hood and said, crap...but I was lucky... I did have to tow it home but....
Redryder pix
My Hotrod
think i will just buy a new one. a guy had that one up for sale for 8 bucks.
thanks for your help guys
-chris-
Here's a question I've had for years, and am very unclear on. Are harmonic balancers custom drilled to balance the engine they're installed on, or are they all interchangeable on a given engine type? Note the drilled balance holes in the picture that was linked to above - would they be unique to that engine, or does the factory just have a gon full of balancers that are pressed onto the engines as they go by?
Fred
Not omly is it cracked but the rubber look's bad too,just replace it!I had one slipping in the rubber,couldn't get it to run smooth,or timed right.Finnally was timing it and it got bad enough I watched the timing mark pass the light!Thought I was seeing thing's.Well anyway new balancer and problem gone!
believe that you have to drill to install the bolt,
mine did not have a bolt, and I dont think it was a dealer option.. I could be wrong though ..but
Redryder pix
My Hotrod
The harmonic balance might have balanced off the engine but I do think it was balanced to match the crank (balanced with the crank).
No bolt was used, at least between 47-55.
If someone has drilled and tapped for a bolt (it has been posted often that a bolt from a 350 crank has been used), would you let us know if this can be done with the crank in the block. I would really like to do this on my 261 before I put the "front clip" back back on my Suburban.
Tim
Mine was drilled/tapped with the crank in the block.
Keeping the hole square to the crank can be tricky but if you have a friend to help, it's not that big of a deal. The guy with the drill looks straight down keeping the bit straight from left to right. The helper watches from the side keeping the drill straight up and down.
Or you can make a guide fixture if you have access to a lathe.
Woody
Door Art Collection
