| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | is it possible and safe to repair a cracked balancer? its cracked on the outer edge. a u shaped crack.
also can a double groove 250 balancer work on a 230?
thanks -chris- | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want to get it repaired, give the Damper Dudes a call. Damper Dudes 6180 Parallel Rd Anderson, CA 96007 530-365-2144 1-800-413-2673 | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Holy cow - $150 for a HB for a 235!
As for repairing yours, it would help if we had a picture. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The dampner is not something I would personally mess with. An exploding one does huge damage and can ruin your crank.It's worth the money to me to have one replaced or properly repaired.
Drew
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I bought one from Langdon's awhile back for my 235, think I paid $45 bucks for it....no problem with it..
looked like a new one..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | HERE'S a picture of the damage. He sent me a photo so I could post it for him. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I think Id opt for finding a decent used or new one. Id hate to have something come apart under the hood at 2500 RPMs...  | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | mine did, that is why I replaced it........I was lucky, no damage to the radiator or fan........the thing just spun off and dropped down below the radiator.
I was cruising about 65 when I heard a noise.. did not think anything of it because an 18 wheeler had just passed me, I then heard a strange noise, looked at my temp gauge, it had started to warm up... pulled off the hiway, open the hood and said, crap...but I was lucky... I did have to tow it home but....
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | think i will just buy a new one. a guy had that one up for sale for 8 bucks.
thanks for your help guys
-chris- | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Here's a question I've had for years, and am very unclear on. Are harmonic balancers custom drilled to balance the engine they're installed on, or are they all interchangeable on a given engine type? Note the drilled balance holes in the picture that was linked to above - would they be unique to that engine, or does the factory just have a gon full of balancers that are pressed onto the engines as they go by?
Fred | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Not omly is it cracked but the rubber look's bad too,just replace it!I had one slipping in the rubber,couldn't get it to run smooth,or timed right.Finnally was timing it and it got bad enough I watched the timing mark pass the light!Thought I was seeing thing's.Well anyway new balancer and problem gone! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | believe that you have to drill to install the bolt, mine did not have a bolt, and I dont think it was a dealer option.. I could be wrong though ..but Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The harmonic balance might have balanced off the engine but I do think it was balanced to match the crank (balanced with the crank).
No bolt was used, at least between 47-55.
If someone has drilled and tapped for a bolt (it has been posted often that a bolt from a 350 crank has been used), would you let us know if this can be done with the crank in the block. I would really like to do this on my 261 before I put the "front clip" back back on my Suburban.
Thanks, Tim | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Mine was drilled/tapped with the crank in the block.
Keeping the hole square to the crank can be tricky but if you have a friend to help, it's not that big of a deal. The guy with the drill looks straight down keeping the bit straight from left to right. The helper watches from the side keeping the drill straight up and down.
Or you can make a guide fixture if you have access to a lathe. | | |
