8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible),
77
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#44868 05/30/2004 9:44 PM | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | Does anyone know of a source for easty to install motor mounts for a v-8. Thinking about taking out the 250 and putting in a 350.
Glen E.
#44869 05/31/2004 12:34 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If the 250 is from it's original truck, the motor mounts may be the same as the small block mounts. If not, go to a parts store and locate them for the V-8 version of your truck. Scott | | |
#44870 05/31/2004 4:40 AM | Joined: Apr 2004 Posts: 21 New Guy | | New Guy Joined: Apr 2004 Posts: 21 | So I should be able to drop a 350 right in with my motor mount frame brackets????? And all I will have to change is the actual motor mount???? Well that sounds easy!
Glen E.
#44871 05/31/2004 6:10 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | My first 63 had a 69, 350 Olds bolted in it, so you don't have to think Chevy, just GM.
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink. | | |
