5 members (Wayne67vert, Otto Skorzeny, dt235sd, Cosmo, Hanks custodian), 85 guests, and 2 robots.
Topics128,059
Posts1,055,825
#44868 05/30/2004 9:44 PM
Does anyone know of a source for easty to install motor mounts for a v-8. Thinking about taking out the 250 and putting in a 350.
Glen E.
#44869 05/31/2004 12:34 AM
If the 250 is from it's original truck, the motor mounts may be the same as the small block mounts. If not, go to a parts store and locate them for the V-8 version of your truck.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#44870 05/31/2004 4:40 AM
So I should be able to drop a 350 right in with my motor mount frame brackets????? And all I will have to change is the actual motor mount???? Well that sounds easy!
Glen E.
#44871 05/31/2004 6:10 AM
My first 63 had a 69, 350 Olds bolted in it, so you don't have to think Chevy, just GM.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink.
