0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#448292 09/02/2008 7:20 PM
My float became dislodged from the sending unit arm likely during the ride to or from the paint shop and I can hear it bumping around in there. Has anybody successfully fished out a float without removing the tank or will I have to drain, remove, and flip it upside down? (This is on an AD truck) Thanks for any suggestions.
Curt B.
You Tube
Curt,
I haven't done this task. Wouldn't it be quite a bit easier to leave the tank intact, remove the sending unit and grab the float from that 'big old hole'. To repair the whole apparatus, the sending unit will have to be removed anyway, right!
Stuart
Id say fill the tank. Itll float to the top making recovery easier! grin
Jeff
My 1953 Chevrolet
1947.1 Gallery
Use a small diameter pipe with a length of string or small wire looped out of the working end.
When you get the loop around the float - pull the string tight.
This is the same type of thing animal control officers use to catch critters from a distance.
Basically a noose on a pole.
Good luck fishin'
Hey - you could use a fishing pole instead.
Good luck. thumbs_up thumbs_up
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
If all else fails, I have taken a gas tank out in less than 1/2 hour and put them back in in about the same time. A Ford 1/2 distributer wrench or a flex handle ratcheting box end makes removing the straps easy. It probably wouldn't hurt to clean the tank out any way or maybe replace it. To me a $120 repop saves a lot of headaches.
