3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#445677 08/26/2008 1:24 AM
am i correct in assuming most mechanical parts from a 40 series 58 chevy truck will fit a 57 350 gmc? Thank you Guy
It really depends. If the engines and trannys are the same, yes. A lot of parts are shared, but overall GMC made a far heavier duty truck. The larger the truck, the more differences you'll find.
What parts in particular are you thinking?
Jeff
My 1953 Chevrolet
1947.1 Gallery
I know the gmc has a 347 pontiac v8, but the 4 spd trans won,t stasy in second. So I,m hoping the chevy 4 spd will work. also the 2spd rearend in the gmc doesn,t work. Lots of little stuff. i USE THE GMC EVERYDAY IN MY CONSTRUCTION BUSINESS, IT HAS 42968 MILES ON IT AND I REALLY WANT TO KEEP IT LOOKING AND RUNNING WELL. i can purchase the chevy 40 series with v8 for $500.oo and figured it would be a good donor. thanx guy
Both transmissions are probably the same SM420 and easily interchangeable. The rear might be an easy swap, but may not and really the only way to know is to compare how they mount.
OldSub #446280 08/27/2008 8:09 PM
If your transmission won't saty in gear it may be bad syncronizers. It isn't difficult to overhaul the SM420 or CH465, it's newer replacement.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dave, whats the 'CH' stand for? I thought the 465s were a Synchro-mesh also???
My 1953 Chevrolet
1947.1 Gallery
thanx guys. another thought i've had is to put the 283 from the chevy in thisv truck. it is tough finding parts for the pontiac engine. can you recommend any suppliers of parts for the pontiac? i need starter, generator and waterpump.It is currently like a ride a six flags to drive. I really want to keep it on the road as it is rust free and straight> guy
guy51usa #446460 08/28/2008 12:05 PM
Ask Mike B about the water pump, he had an adventure with his last year about this time. And I think he has also found a spare.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #446538 08/28/2008 3:59 PM
Plenty of Poncho parts around. Just search the internet or go to www.Kanter.com.
Dave
