Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 470 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#444399 08/22/2008 3:18 AM
Is there a reasonablly priced alternative to a respirator for those of us with to much facial hair???
I have a fairly decent one that works pretty good for the most part. When Im really going at it I try and use the respirator, goggles and a full face mask and sometimes even a few t-shirts to keep the crap out of my face, mouth and lungs. But I always wondered if there was something that would work a bit better?
Im referring more to blasting, grinding, wire wheeling, etc.
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #444591 08/22/2008 3:55 PM
You could use a diving bell Jeff or just SHAVE like the rest of us civilized men do.
Just pullin' yor jeeber Jeff, I know where your comming from, I used to keep a beard every winter years ago and had the same problems with the dust maskes. the beard made them pretty much usless.
Of course with the blasting you should be using a diving bell or rather a hood with fresh air coming in. That taint very practicle for the otheres though. Even the full face masks for spraying won't cover a full beard.
Now if you are willing to get rid of the full beard and just keep one of those Devil beards like Bruce Springstine and other celebs have that would solve your problem also.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #444607 08/22/2008 4:31 PM
Auto Restorer magazine had an article several months ago that described modifications to divers scuba gear to use for painting.
Harold Wilson
41 Chevy 3/4 Ton
Harold41 #444728 08/22/2008 10:33 PM
Ex Hall Monitor
Ex Hall Monitor
I looks like you're more concerned about particulates. A plain old dust mask will work great. The beard will stop about any particulates the size you refer to. My face has been unshorn for over 40 years & all I used while sanding/grinding was a dust mask. The biggest problem I had was where it fits around the nose. No problems at all pulling crud through the beard.
Tiny #444841 08/23/2008 4:24 AM
You just have to think of your beard as something kind of like the element on a oil bath air cleaner. Just soak it in oil for a while before you work and it should catch all those particles!!
I'm just being a smarta$$ Jeff.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Old Gold #444969 08/23/2008 6:58 PM
I like it! grin
My 1953 Chevrolet
1947.1 Gallery
rustednuts #445033 08/23/2008 10:53 PM
I've wondered about these. They're cheap enough to try:
http://cgi.ebay.com/Russian-GP-5-Civilian-Protective-Gas-Mask-Adult-size_W0QQitemZ150284192339QQcmdZViewItem?hash=item150284192339&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
GreenGMC #445043 08/24/2008 12:14 AM
I dont know, I might spook the neighbors grin and be arrested in some terrorist plot! eek
My 1953 Chevrolet
1947.1 Gallery
rustednuts #445392 08/25/2008 1:56 AM
All joking aside, ask any industrial hygenist and he'll tell you that the finer the particle the more damage it does to your lungs 'cause they get injested deeper down into your lungs. There's only one way to have a good seal with a resperator and that's a clean shaven face. Also, those cheap paper dust masks (plain old dusk masks?) are no protection at all. I have a half face and a full face with air supply at my job and they both require a clean shaven face. I even had to shorten my fu mancho !
rustednuts #445394 08/25/2008 2:00 AM
I worked in a shop as a painter and metal refinisher that had a awesome down draft bench, iron grating over the top. I have thought many times that it would be great to have my grinding wheel or buffing wheel used over something like that (universal mount). The motor was explosion proof since it was mainly used for spot primer on small items for finish sanding and cleaning metal after buffing with thinners prior to clear coating, but the draft could flush the air in the shop in less than an hour.
If you have ever been on an industrial grinding wheel or buffer for any length of time you know that your cloths with be riddled with tiny holes that grow with each washing or black with dust that will ruin any good maytag and still be gray.
1937 Chevy 1/2-Ton
Moderated by  MNSmith
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.113s Queries: 14 (0.040s) Memory: 0.6361 MB (Peak: 0.7220 MB) Data Comp: Zlib Server Time: 2025-09-22 08:58:08 UTC
Valid HTML 5 and Valid CSS
