2 members (baldeagle, 1 invisible), 90 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#443640 08/20/2008 1:03 PM
TPB
Offline
I just painted my garage floor and I thought I had fixed all the leaks. I ordered a oil pan and that should stop that leak but I get a leaking from the front universal joint. I don't see a place for a gasket. Any help would be apprieciated.
TPB #443650 08/20/2008 1:30 PM
TPB,
If you have a 1/2 ton 1951 with the original torque-tube there is one u-joint inside a bell/ball right behind the transmission.
A good u-joint ball gasket and seals kit includes:
1. several gaskets that go between the ball-housing collar and the transmission (check the Shop Manual for number of gaskets to use)
2. a seal that goes between the collar and the ball
3. a seal that goes in the neck of the collar and seals around the torque-tube
Tim
tclederman #445303 08/24/2008 8:51 PM
TPB
Offline
i have the best gasket universal joint set #5151 but I don't think it has those blues gaskets. It is for years 1929 to 1951.
TPB #445374 08/25/2008 12:50 AM
I wonder what changed in 1952?
In the Classic Parts set of gaskets/seals, the blue gaskets (4 of them - some other sets only come with two gaskets for this location) that go between the ball-housing collar and the transmission. I think the black gaskets might be for the 3/4 tom which has a short enclosed piece of driveshaft that attaches to the rear of the transmission.
tclederman #446362 08/28/2008 12:41 AM
TPB
Offline
the manuel has no reference to gaskets but I purchased the kit you recommended
TPB #446758 08/29/2008 4:23 AM
The 4 gaskets are used basically as shims and can be easily made from gasket material. Having more than one in position on the ball housing/transmission join takes up the slack (described in the shop manual) and if a leak develops loosen the bolts and a gasket can be torn out and the bolts tightened up to make it drip free.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #446810 08/29/2008 12:14 PM
The Master Parts Catalog indicates that the same seal kit is used for 1/2 tons from 1929-54. It looks as of the black, 6-hole shim/gaskets are for the 1954 Hydramatic.
Hoyt
hoyt #446860 08/29/2008 2:30 PM
Hoyt,
You are right about the 6-hole 1954 hydra-matic seals. What type of cover goes over the u-joints on a 3/4 ton u-joints/driveshaft extension tube?
Tim
