3 members (PAUL Berardi, Paul Mullen, stlcardinalsguy), 157 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#444434 08/22/2008 4:38 AM
I added a '54 2-ton to my fleet last year and pickup up a 55.1 2-ton to use for parts earlier this summer. I've been taking the parts truck down to the frame to do a general clean-up, new brake-lines etc. One of the front spring hangers had shackle pin stuck in it that wouldn't move. I also couldn't pull or drive the bushing out with the usual puller/hammer/heat or any combination of them.
It was about then that I remembered I had this ancient and huge puller setup I'd bought at a garage sale 20+ years ago.
Here's a link to a short series of pictures of the operation:
Hardcore Pin Removal
That's an 18-inch Crescent wrench on the ground in one of the pictures and it took all of it before the pin started to move.
You might be able to find a rental outfit that has a puller setup similar to the one I used. It sure worked when nothing else would.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
I picked up a Snap-on Kingpin remover at a garage sale a few years back for $20. I just recently go to use it and with a 6' piece of 1" pipe and a 3/4" drive socket I barely broke a sweat!
It looks very similar to your tool and has a bunch of different sized pins for pushing, and interchangeable bushings for everything from light duty to heavy duty applicatons.
Glad you got it out! With a little time and some ingenuity you could probably make something similar that would do the job. cool
Jeff
My 1953 Chevrolet
1947.1 Gallery
Hey Jeff could you add a picture of that Snap-On Kingpin Remover to your album, I'd really like to see what it looks like.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny I dont have our camera right now, but when I get it back Ill let you know and provide some pics.
Jeff
My 1953 Chevrolet
1947.1 Gallery
yep i have a set up like that works good,some time's use a otc ball joint press ,you can put the screw's to it with a impact !
old dog #447698 09/01/2008 2:13 AM
Denny heres the pictures you requested.
Complete tool in the box.
Tool and pusher pins.
Closeup of the instructions.
There are three different ends depending on the size of the kingpins. Two rounded nuts hold the end piece on. The general purpose one is attached as shown. When doing kinpin removal on a car with smaller pins, there is a bushing that sits inside the end piece. The pins are all different shapes, sizes and lengths. They fit inside the threaded rod which presses the kingpin out as you torque her down.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Thanks Jeff, I copied those pics to my tools folder. I tied to copy the Webshots pics that Olblue posted but it says that “This photo may only be saved by friends” and how one becomes a friend in webshots I have no idea, they have destroyed the site since it was taken over last year. I’m getting out of it as soon as I can.
Thanks again,
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
not to sidetrack the thread, but I've concluded you're right Denny, webshots will be losing my traffic too .... but now ya see about my problem with getting the friends message on your pics
Thanks again,
Denny Graham
Sandwich, IL
I recommend photobucket. It's free and easy to use. You can also do slide shows and make clickable images that use very little bandwidth like the following.
[IMG]http://img.photobucket.com/albums/v228/Avette4me/My%2058/th_Karaandthe58.jpg[/IMG]
