Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#44282 01/29/2005 11:56 PM
Junior Member
Junior Member
hi guys, time for my first post. Has anybody fitted one of these to their engine?
How it works
When a spark plug fires, the capacitor block attached to each spark plug wire picks up a high voltage, low current charge. This charge is transferred from the firing cylinder to the other non-firing cylinders via the harness wire. These charges cause a partial breakdown in the larger hydrocarbon molecules in all the non-firing cylinders, resulting in increased combustion efficiency. This translates into better fuel mileage (economy), increased performance, easier starting, less pollution (lowered emissions), smoother idle.
Thought I might give one a go if it helps overall. My truck "fiddy" runs pretty rich-i think a carby overhaul is the main fix but if this helps?.....
aaahh..the smell of my old truck...
#44283 01/30/2005 3:41 AM
Many years ago, there was a man named P.T. Barnum. He had a philosophy of life that's been emulated by the manufacturers of gimmick ignition parts for a long time.
"There's a sucker born every minute!"
The first time I saw that system was in the late 1950's. It didn't work then, and I seriously doubt that it's improved much in the 45 years since gullible people were buying it then. A well-manitained conventional ignition system, or one of the electronic-controlled systems will work a lot better.
#44284 01/30/2005 9:39 PM
If it works I figure US auto makers would have used it when the government mandated better fuel economy and less emissions.
#44285 01/31/2005 7:12 PM
I dunno about the ign thingy , but you've got a very nice looking truck there Jason , I'm in ChCh weekly and look forward to seeing it out and about soon grin
#44286 02/01/2005 4:13 AM
Junior Member
Junior Member
thanks for your thoughts guys, i think i will just invest the $$ in a tank of gas!
Cant wait to see ya cruizin around Dusty!(better get me truck complied first i spoze!)
#44287 02/02/2005 8:55 AM
This scheme would reduce the available energy to the spark plug that is currently firing. I have a couple of engines that have distributorless ignitions that fire the plugs on each cylinder on the exhaust stroke as well as the compression stroke. I haven't noticed any differance in carbon build up, in fact the plug electrodes seem to wear out faster.
Paint & Body Shop moderator
#44288 02/04/2005 6:46 AM
Doesn't sound viable to me either.
If you want cleaner emissions, there's always a catalytic converter. Not to sound like a smart-ars or anything...but that is a proven technology.
I can understand wanting to run a cat, if you don't like the exhaust fumes wafting in through open windows in the summer. You can always run a cat, even if you aren't required to. The modern high flow cats don't significantly affect horsepower anymore. And go for about $65 at Summit.
But watch out for these "snake oil" solutions.
A capacitor would steal some of the spark energy to charge itself up, and that would definitely reduce the voltage across the spark gap, resulting in even more incomplete combustion.
Why not consider a multiple spark ignition system? There are several out there, and they definitely work. Hotter spark and multiple spark, will result in better combustion and greater efficiency.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
