2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i have one clutch flywheel and pressure plate with 9 bolts in the pressure plate it sort of looks like a 50s flying saucer. i have another that looks more like im used to seeing with less holes 6 i think but im not sure. do you guys have a preference its going in a 1960 235 philip | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Unless you need a good grabbing clutch for performance reasons, I dont really see any reason that one should be chosen over the other. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | well it is a 2 ton so i need a good clutch i chose the one with the best looking flywheel and pp | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 9 bolt one is what I have in my 1 ton, and it is used in the larger trucks.
Grigg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If the pressure plate surface is heat crazed and blue, you might want to take it to a machine shop to resurface it. I did not do that recently and the truck shuddered when releasing the clutch at a stop. | | |
