2 members (Peggy M, panic), 89 guests, and 4 robots.
Topics128,030
Posts1,055,428
Members48,422
#441385 08/13/2008 8:29 PM
i have one clutch flywheel and pressure plate with 9 bolts in the pressure plate it sort of looks like a 50s flying saucer.
i have another that looks more like im used to seeing with less holes 6 i think but im not sure. do you guys have a preference
its going in a 1960 235 philip
philip t #441444 08/13/2008 11:00 PM
Unless you need a good grabbing clutch for performance reasons, I dont really see any reason that one should be chosen over the other.
My 1953 Chevrolet
1947.1 Gallery
rustednuts #441737 08/14/2008 8:33 PM
well it is a 2 ton so i need a good clutch i chose the one with the best looking flywheel and pp
philip t #441749 08/14/2008 10:15 PM
The 9 bolt one is what I have in my 1 ton, and it is used in the larger trucks.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #441765 08/14/2008 10:59 PM
If the pressure plate surface is heat crazed and blue, you might want to take it to a machine shop to resurface it. I did not do that recently and the truck shuddered when releasing the clutch at a stop.
