6 members (Barry Martak, TUTS 59, KEVINSKI, 78buckshot, Peggy M, tclederman), 104 guests, and 3 robots.
Topics128,096
Posts1,056,482
Members48,444
#439922 08/08/2008 7:33 PM
Does anybody know if they are interchangable? are they the same?
Ed
Depends on the truck.
Typically a 1/2 ton will swap with a 1/2 ton, etc, etc. There may be a difference in length between a 3 speed or 4 speed driveline also.
Jeff
My 1953 Chevrolet
1947.1 Gallery
prior to 1946, 1/2 ton and 3/4 tons had the same lug pattern...6 lugs on 5 1/2 inch bolt circle. in 1946... 3/4 tons got the new 8 lug configuration. 41-46 1/2 tons had full torque tubes... 41-45 3/4 tons had an open driveline rear end.
