1 members (walter74),
78
Mod | | | Forums66 Topics128,096 Posts1,056,477 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Does anybody know if they are interchangable? are they the same?
Ed | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Depends on the truck.
Typically a 1/2 ton will swap with a 1/2 ton, etc, etc. There may be a difference in length between a 3 speed or 4 speed driveline also.
Jeff | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | prior to 1946, 1/2 ton and 3/4 tons had the same lug pattern...6 lugs on 5 1/2 inch bolt circle. in 1946... 3/4 tons got the new 8 lug configuration. 41-46 1/2 tons had full torque tubes... 41-45 3/4 tons had an open driveline rear end. | | |
