2 members (Waveski, Steveoreno),
80
Mod | | | Forums66 Topics128,184 Posts1,057,267 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | My gas tank is leaking a bit in my '62. I could have it professionally sealed and put it back in, or I was thinking of getting a larger capacity tank and putting it in. I'm going to move the spare tire to the inside of the cargo area, on a bracket welded to the driver's side wall. I'm going to cut storage compartment into the passenger side wall, with a factory looking door/access cover, and store a modern truck's jack kit in there. this opens up the space under the cargo floor for a bigger gas tank.
What has everyone used?
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2006 Posts: 102 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 102 | I patched my original tank 2 times and then I mounted the spare inside using part of a kit made for mounting the spare on van barn doors and went with a polyetheline tank from Brothers. It's not bigger but it won't rust!I also mounted a tool box over the passenger side wheel well that is really ment for a pick up box. You can see my interior set up in the photo section under eb's 63 | | | | | Joined: Jan 2009 Posts: 21 Apprentice | | Apprentice Joined: Jan 2009 Posts: 21 | Classic truck parts sells a complete to install in the old location without the dent for the spare for about 200$. it comes complete even a sender. | | |
