7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna), 140 guests, and 4 robots.
Topics128,204
Posts1,057,294
Members48,467
My gas tank is leaking a bit in my '62. I could have it professionally sealed and put it back in, or I was thinking of getting a larger capacity tank and putting it in.
I'm going to move the spare tire to the inside of the cargo area, on a bracket welded to the driver's side wall. I'm going to cut storage compartment into the passenger side wall, with a factory looking door/access cover, and store a modern truck's jack kit in there.
this opens up the space under the cargo floor for a bigger gas tank.
What has everyone used?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
I patched my original tank 2 times and then I mounted the spare inside using part of a kit made for mounting the spare on van barn doors and went with a polyetheline tank from Brothers. It's not bigger but it won't rust!I also mounted a tool box over the passenger side wheel well that is really ment for a pick up box.
You can see my interior set up in the photo section under eb's 63
Apprentice
Apprentice
Classic truck parts sells a complete to install in the old location without the dent for the spare for about 200$. it comes complete even a sender.
