BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
3 members (68ironhead, JW51, 1 invisible),
574
robots. | Key: Admin,
Mod | | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | I've always known you bleed the longest line first then the next longest line etc. Reading the online manual today it said Left rear first(I assume thats driver side), left front, right rear and right front-
I've been doing right rear(passenger), left rear, right front left front. In my mind I considered how far each was from the master cylinder..BUT the way the lines are layed out can fool you..was very surprised the the left front is longer than the right rear..I thought that was the shortest one..man no wonder it takes me days to bleed em.
Just wanted to post this incase I'm not the only dummy..
Keith | | | | Joined: Apr 2005 Posts: 507 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 507 | Never assume anything !!!! You have also assumed that by the left rear they ment from a position in the drivers seat. Not so fast, looking at the truck from the front the left rear is the farthest wheel cylinder from the master, then the right rear, and the left front and so on. The manual does not say in what position the writer considered the direction right and left,was he sitting in the drivers seat or was he standing in front of the truck/car? You have been doing it correct all these years. All the manuals that I have used and there have been way to many. You always start with the wheel cylinder that is the farthest from the master cylinder and work your way around the truck/car doing the cylinders in order from farthest to the closest the length of the lines don't really matter. I have been doing it this way for over 40 years and it has worked well to this point. Just my 2cents!!
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | I hate it when I thought I was wrong..but it turns out I'm right..But I still don't believe I was right.
The manual goes from rear to front-rear to front..I was doing the rears then the fronts...
I know the writer didn't explain if he was sitting in the truck or facing it-I think when you go to your local FLAPS to buy something-they consider drivers side as Left and the passenger right..so I went that way..
The front drivers side is deceiving--although you would think it's the closest wheel cyl to the master cyl..I believe it exits the master towards the rear of the truck, cuts over to the passenger side, turns towards the front of the truck..goes to a junction of 3 lines..then goes to the front passenger side cyl. Almost goes in a circle..
I'm gonna have climb under there tonight..
Thanks for the $02
Keith
| | | | Joined: Feb 2000 Posts: 769 Shop Shark | Shop Shark Joined: Feb 2000 Posts: 769 | When bleeding brakes, it is the cylinder that is the farthest from the MC by the length of the brake line; not as the crow flies. | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Left and right are always from the drivers seat. AD trucks have the brake lines crossing over to the right (passenger)side and then heading towards each wheel. That's why the left side is farthest from the master (which is on the left side), Scott | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | Shop Shark Joined: Dec 2003 Posts: 1,554 | Ive been bleeding brakes for many years in the same fashion,always works OK for me.Passenger side rear,drivers side rear,Pass.side front and last drivers side front.Right or wrong in your book this gets the air out of the lines,and that is the purpose of bleeding the brakes. | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | It seems to me that the length of line would be instrumental. I believe the theory is that if you don't bleed the longest to shortest you can create a trap..a section with air that never gets bled out.
Actually this is good news-although I have always achieved a good pedal in the past 4-5 times I've needed to bleed, it's been murder. Maybe this is why.
Keith | | | | Joined: Jan 2004 Posts: 223 'Bolter | 'Bolter Joined: Jan 2004 Posts: 223 | It is the length of the lines that control, not the as Lonnie states 'as the crow flys'. This also changes in the AD lineup. I know that the pre 1950 trucks the left (driver's) side front line came for the right across the front crossmember. This changed at some point later on and went from the MC directly up the left frame rail.
| | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | Task Force also crosses from MC on left to the passenger side-after first going towards the back a foot or so..
Keith | | | | Joined: Feb 2000 Posts: 769 Shop Shark | Shop Shark Joined: Feb 2000 Posts: 769 | Nifty 50,
Read my post again, as I stated it is the length of the line, not as the crow flies.
Not all years and models of the ADs are plumbed the same, therefore it is important that the lines are checked for length. | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | I think you've made your point that perfectly clear..
Thanks.
Keith
| | | | Joined: Apr 2005 Posts: 345 Shop Shark | Shop Shark Joined: Apr 2005 Posts: 345 | Slickriffs, You were right in being wrong the first time. When replacing brakes last week I noticed, as stated above, that the brake line comes to the rear along the right (passenger's) side of the truck and then tees off to the rear brakes. The left brake is farther from the tee, and consequently farther from master cylinder. That is why this side needs to be bled first. | | | | Joined: Jul 2005 Posts: 640 Shop Shark | Shop Shark Joined: Jul 2005 Posts: 640 | Are you guys talking about bleeding an empty system? I would think that if you're just changing the front, or just the rear wheel cylinders, the only air in the system will be at those wheels. Am I wrong? | | | | Joined: May 2006 Posts: 8,351 'Bolter | 'Bolter Joined: May 2006 Posts: 8,351 | Always best to bleed the entire system if it's been opened up, even if it's just on one end. Or even one wheel for that matter. Cheap insurance. Off topic, sort of, on new cars, they use a diagonal split braking system. So that means that, depending on vehicle, you could have a sequence of RR-LF-LR-RF, and in some cases, having to bleed 1-4 bleeders on the ABS module.
Bill Burmeister | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | Enjoying the responses..Even the most basic chores may be misunderstood..I learned something today..
Now..what about tomorrow?
Thanks all..some good stuff here..
Keith | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | 'Bolter Joined: Mar 2004 Posts: 3,068 | Now, if you use a power bleeder, it doesn't really matter where you start, although farthest is still recommended, Scott | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks Scott..Just ordered a relatively inexpensive power bleeder this afternoon..Can't hurt to keep the order right thou..
I've done it in the wrong order for many years..and eventualy did get good results..But there's always room for improvement..
Keith | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | Shop Shark Joined: Sep 2007 Posts: 2,644 | Left and right are always from the drivers seat. Always! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive been doing them for 55 years & find it really doesn't make any difference. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | Joined: Dec 2002 Posts: 3,374 Moderator - The Electrical Bay | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,374 | It doesnt hurt to ensure that you flush out all the old fluid every year or ten..
| | | | Joined: Oct 2002 Posts: 4,066 Bolter | Bolter Joined: Oct 2002 Posts: 4,066 | I never thought it made any difference, .......... but I never just changed one brake shoe without changing all of them, or at least both on the same end, front or rear......
never flushed out any brake fluid or changed transmission fluid in an automatic.......................a lot do though..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | Just to finish this thread off-
I bought a pressure bleeder with a cap especially made for that old Stovebolt style master cylinder. I bought it on line from a company called Motive Product. I have no association with them.
Unpacked the unit..Hooked up a few things and tested it to hold pressure..then filled it with new DOT 3.Screwed the temporary cap in the master cylinder. Pumped it up to 15 lbs..and just put a clear hose (provided) on the wheel cyl bleeder..opened it with a wrench and watched til the fluid ran clear of bubbels. The first wheel alone(left rear) made a big difference. 20 minutes later the work was completed and I had a rock hard pedal.
Not say'n you can't do it the old way...I've done it that way for 40 years..But this is so convenient..especially when you work alone. I will expand on this in another thread..
One last thing..how this thread started..Bleeding longest to shortest..many of us accept that..I do..However my truck, with original lines, did not conform to the manual online..my 55 3/4 ton was..Longest:Left rear..then Right rear..Then Right front..then Left front
Keith
| | | | Joined: Mar 2005 Posts: 637 Shop Shark | Shop Shark Joined: Mar 2005 Posts: 637 | I have an antique (probably from the '30's) pressure bleeder, it is about 16" diameter and 8" high, has a pressure gauge on top and different ends that fit most master cylinders. Slickriffs got a modern version of this thing, mine still works like new, makes a no helper brake bleeding job simple and foolproof. | | | | Joined: Jan 2008 Posts: 227 Shop Shark | Shop Shark Joined: Jan 2008 Posts: 227 | Call it Aussie inginuity, bush mechanics or whatever.......
........but I made up a spare master cap to which I drilled a hole and fitted a standard tubeless tyre valve.
To this I set my air inflator and regulator to a small 8 psi setting and hopped under the car to work the bleeders, only stopping occasionally to check the level in the master.
It's great not having to ask the missus "Foot down, hold, foot up" two thousand times! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | LOL..My wife has done that a number of times..She's good at first..But then starts whining..I guess I can't blame her.
Keith | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | 'Bolter Joined: Oct 2006 Posts: 9,671 | Keith, I looked at that bleeder from Motive Products, nice little set up for home, a little pricey for a plastic bottle, cap and hose but being from the old school, every thing looks out of line lately. Say that mate, that might work but without a decent sized reservoir your going be bleeding off air and pulling that cap dozens of times to do a complete fluid change. The master cylinder reservoirs are really tiny.
Chevman, I got ya beat, I've got a pressure bleeder from the late 50's from a Chevy dealer that I was working at. It needed some repairs so they had just pitched it out. It's a metal housing with a rubber bladder that holds about a gallon of fluid. Pressure in the housing forces the bladder to collapse forcing fluid out. This keeps the fluid in a sealed container and out of contact with the air and moisture. The problem with it is, the rubber bladder rots away over the years and no replacements are available anymore. The problem I see with the plastic bottle from Motive is the fluid is open to the air supply, moisture and atmosphere. Not the best environment for brake fluid, which is very hydroscopic, and has been the subject of discussion on several occasions here. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | Motive suggests that brake fluid not be left in the unit.
The price of the Motive unit is a little more reasonable once you see the beautifully-machined thick-metal cap/cover for attachment to the master cylinder. | | | | Joined: Jan 2007 Posts: 615 Shop Shark | Shop Shark Joined: Jan 2007 Posts: 615 | actually you don't leave the fluid in the tank after you use it | | | | Joined: Jan 2004 Posts: 223 'Bolter | 'Bolter Joined: Jan 2004 Posts: 223 | I don't get to check the board as often as I would like, but I need to back to the first page and my earlier post to make it clear. Better word choice and punctuation hopefully would have made it clear that I was agreeing with Lonnie. i.e. "not, as Lonnie correctly stated, as the crow flies." Steve | | |
