0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | I went to replace the front brakes on my 66 c-10, and they were completey bare. Any idea what size the wheel cylinder bolt is?
"you can't fix stupid"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm not sure what you mean by "wheel cyl bolts". If it the mounting bolts they are 5/16 coarse thread. About 1/2 in long. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | the bolt that mounts the wheel cylinder to the control arm.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Do You mean the backing plate to the arm? Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | its the bolt that mounts the wheel cylnder to the spindlenot the backing plate to the contol arms. it is a large bolt.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Captain,
I think something is being lost in translation here. The wheel cylinder is the small hydraulic piston that actuates the brake shoes on each wheel. It should be held on with two small bolts that go through the backing plate.
Is this what you are referring to. There is a large round hole in the backing plate that a machined step on the wheel cylinder goes through. This machined step has the bleeder and the threads for the brake line in it.
Does yours work this way too!
Stuart | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | no not on a 66. there are 2 smaller holes that attach the backing plate on. there is the larger hole for the brake line, and the bleeder. then there is a hole above that one for the mounting bolt.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think you are talking about the shoe stopper that has the spring anchor built into it that sits just above the cylinder. It's more that just a bolt I think. It should look simular to the rears if you want to look at it. Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The top hole is not for the wheel cylinder, that is the anchor pin for the brake return springs. It's the 2 smaller bolts that actually hold the wheel cylinder on. The backing plate is held to the spindle by 4 bolts, should be 2 short and 2 long bolts, 1/2' diameter. The GM Duo-Servo brake system (Bendix style) is more or less the same from 1951 to 1999, with the addition of a self adjuster in the mid '60s.
Bill Burmeister | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | thank you 48bigtrucks. longbox, you are confusing yourself.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | longbox, you are confusing yourself. Not sure I follow. I'm an ASE Certified brake mechanic by trade.
Bill Burmeister | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | Well the wheel cylinder on my 1966 c-10 pickup is only mounted by the one bolt, which also has the anchor for the springs.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's certainly different from anything I've ever seen. Must have only been used for a few years. Looks to take a special bolt, since it also serves as the return spring anchor. I could find no listings for one, not even in Dorman.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Another weird GM idea, like that goofy passenger side mounted hydraulic clutch they used for 61 and 62, or one of those years... | | |
